CRG Research Data Submittal Form
©1998-2007, Camaro Research Group
Edited by
Version: Mon Apr 28 18:58:54 EDT 2025
The CRG collects data on first-generation Camaros for research purposes, and the CRG thanks in advance anyone wishing to participate by volunteering data on their 1967-1969 Camaro.
Note: All information submitted is strictly confidential and will be used only for research purposes as part of the Camaro Research Group vehicle analysis database. Summaries of findings from database research may be published on this web site as well as in other publications - however, it is the intent of the CRG that VIN data and owner personal data will not be published or released without prior owner consent.
  1. Boldfaced items are required, all others are optional.
  2. Note that the options to be selected are factory options. Items added later aren't useful for our research.
  3. Note that we have broken up the option input into 5 chunks. Engine and Transmission options are selected separately. A Main list of options is provided that contains the bulk of the options that many without original documentation might know about. Wheels and Tires are listed in a fourth list. And Other, Low Volume, and Non-Dealer-Selected factory options such as might appear on a GM of Canada computer printout, for those that have access to this, are listed in the fifth option list.
  4. If you are unsure about or can't locate the data for a non-required data item, or you don't believe an item to be applicable to your car, simply leave it blank.
  5. You can ask questions in the comment box at the end of the form; one of us will get back to you as soon as we can (if your email address is correct).
  6. Remember to click the submit button at the bottom of the form - if you don't, we will not receive the data.
Your Name:
Your E-Mail Address:
Your Street/PO Box Address:
Other Postal Code:
City:
US State or CA Province:
Zip/Postal Code:
Country:
Work Phone:
Home Phone:
FAX:
Model Year:
Model Style:
VIN: Ex: 124377N123456
Factory Options (RPOs):
  Please select known factory options only. Options added by the dealer or an owner can be described in the comments section at the bottom of this page.
Main List:
(Depending on your browser and computer, you may need
to press a key like Ctrl in order to make multiple RPO
selections with the mouse.)
Wheel and Tire List:
Other/Low Volume/Non-Dealer List:
Cowl Tag:
BODY BY FISHER
Date Code: Scheduling or Int Paint Code:
ST BODY
TR PAINT
Fisher Codes:
(The data layout above is similar to the format of most 1967-68 tags. However, the 1969 tag format is slightly different and merges the data on the upper line with that on the bottom line.)
Original Engine:
Engine Assembly Stamp Code: Ex: T0123HB
Stamp location: V8 - on pad extension of block in front of passenger-side cylinder head; L6 - on pad extension of block near distributor.
Engine VIN Location:
Engine VIN: Ex: 19L543210
Original Transmission:
Transmission Assembly Code: Ex: P9S29
Manual transmissions are stamped on the maincase, but the location varies: Saginaw - stamped on the machined surface on the left side of the case just below the side cover; Muncie - stamped vertically on the maincase casting at rear surface or flange on the passenger-side just ahead of the extension; Powerglide and THM350 stamped on right side of the transmission oil pan; THM400 stamped on a removable metal ID plate located on the right hand vertical surface of the transmission case.
Transmission VIN Location:
Transmission VIN: Ex: 19L543210
Location varies: Partial VIN often stamped on maincase upper surface, or near application stamp.
Original Rear Axle Type:
Rear Axle Stamp: Ex: BE0123G
Stamp located on front face of passenger side axle tube
Rear Axle Radius Rod (1967 ONLY):
Positraction:
Seat Belt Data
Input data on up to 14 belts
    Ex: 131 Ex: 45-A-67
    or 2950 or 12-C-69
Model no: Date code:
Documentation Available
Protect-o-Plate: Window Sticker: Body Broadcast Copy:
Chassis Broadcast Copy: Invoice: Other (Please describe in comments):
Comments:
Please use the box provided above for any additional comments you have regarding your Camaro and or optional equipment...
Please review your form for accuracy, if it becomes necessary to make a correction, you may go back and change an individual field or by pressing the reset button change all fields back to the default settings...To submit simply press the submit button below!
After you submit your data we will contact you via email if we need clarification of the submitted data. We may also contact you in the future for further data related to your car when a research issue arises that pertains to your car.
