Main Menu
How big of a tire will fit on the front of a 69
Started by sixt9x33rs, February 01, 2014, 11:27:08 AM
Previous topic - Next topic
sixt9x33rs
I am thinking about putting four P235 60 R15 on all corners of the Silver Z with the Torque Thrust wheels and will put original style tires on the Rallys. Will this size tire fit the front of the car without rubbing?
I don't know about your wheel sizes or offsets, or which brand of tire you are considering, but back in the '70's in attempt to put more rubber to the road on my '69Z RS, I used 235/60-15 BFG Radial TAs on 8" Corvette Rallyes, and I had issues with the front.. during sharp turns they rubbed against the bolts holding the inner fender to the fender so I exhanged those bolts for rounded head allen screws, then I found the tires were scrubbing against and wearing thru the plastic covers behind the RS actuators.. so I finally took them off, and put back the 15x7 wheels.   A friend had the same size tires on 7" rallyes on his car, and he had no issues, but his car wasn't an RS, and his car seemed to sit higher, as I believe the springs had been exchanged for 'BB' springs..?
sixt9x33rs
I am running 15 x 7 Torque Thrust. The springs are a concern because they are the original ones and they do sit lower than the Gold car with new Moog Z28 springs. I am going to measure the tires when I get to the tire store and see what is up.
vonroll
I'm running (gulp) 245/60-15s on stock rally sports and yes they rub big time.  I didn't notice them rubbing on my test drive on reasonably flat roads.   Now that I'm driving the hill country back roads in central Texas, I feel it big time.   The fronts rub a lot more than the rear.  I've seen recommended size being the 215/60-15s, so I'll be trading out the fronts soon.
69 Z/28, 01C,  X77, 711, 72 BPNT.   Hugger Orange, Black Vinyl Top
sixt9x33rs
I put the 235 60 15's on and they seem to be ok. For now...will see.
My all-original unrestored '69Z came to me with BFG 235/60-15 T/A's on the stock YH rallys, and the fronts rubbed at 12 o'clock on the bright wheel opening moldings and bolts. I swapped the whole set out for 215/65 T/A's (same size as the original E70-15's), and the rubbing is history.
sixt9x33rs
These tires are going on the Silver X77 original paint car. As far as I know it too has not been restored (looks that way anyway). The car naturally does not have the wheel well moldings so no rubbing on those or the inner radius of the fender. I have driven the car over speed bumps, down the road made turns etc. and so far so good, no rubbing. The torque thrust wheels that these tires are on are 15 x 7.
I do need new tires on the X33 car so good to know that the 215 65 70R15 fit well on the YH wheels. I will consider those tires. I currently am running 1993 vintage (ouch) P215 70 R15 BFG T/A Radials that don't rub at all. BUT the car has new springs in the front and re-arched stock springs in the back.
Steve Shauger
I had rubbing issue on my Yenko and Orange Z and I found the solution was to put 215-65-15. The 70 series rubbed just enough to annoy me :)
Steve Shauger
Quote from: sixt9x33rs on February 05, 2014, 08:24:31 PM
You should check the plastic covers over the HL cover actuators to make sure the tire isn't scrubbing it.. they are easily damaged.
Stingr69
245-60-15's on 7" Rally Wheels here.  I had to bend the lower edge of the front fender extension/moulding forward a small amount.  No permanant damage and clears/looks fine that way IMHO.  The inner side of the tire can touch near the subframe at full lock left or full lock right some times but on my driver car, it just does not matter much.  I would not worry but maybe some of you would.  I might go with 235-60-15's next time (but that might not ever happen).
-Mark.
sixt9x33rs
The 235 60 15's are on the x77 car not the RS car.
My Pace Car rubbed on the actuator covers with FW series rallys and 235 tires. I am now running 205/50/15 TA's on the same FW's, and they do well. A little narrower than I wanted to run; shorter, too, but when I put NOS actuator covers on it I didn't want a repeat rub. Car sits well, almost like it's running 14 X 7 YJ's in stance.
sixt9x33rs
I am running P215 70R15 on my RS Z28 with no problems. I like JohnZ idea of running 225 60 R15
Quote from: sixt9x33rs on February 06, 2014, 10:21:30 PM
Actually, in reply #5 of this thread, JohnZ stated that he changed over to:    "215/65 T/A's"
