1967 Camaro v6 engine
Started by Jbyer8, September 23, 2013, 07:41:00 PM
Jbyer8
Looking to purchase a 67 camaro. The vin reflects the engine originally being a v6. The current owner selling has a 350 crate 4 barrel carb engine in it. This was the way he purchased.
Anything to worry about? Pretty novice when it comes to engines and gen 1 camaros.
Jbyer8
Just a follow up. I'm not looking to drag race or enter car shows. The seller is asking 20k for it. I just want to make sure this combination won't cause me a lot of problems down the road,
Probably a lot (to most?) of the 6 cyl Camaros have been converted to V8's over the intervening 45 or so years...  by itself, it's nothing to worry about (although NOT original), but I'd also want to know what else he changed to the V8 item (springs?, trans?, rear end?, etc).   The trim tag shows you how it was built originally, but after 45 years one has to play detective to see what has been changed, and how well it was done...
tom
By the way, no v6 on any first gen. They were all inline or L6's
69 X11 Z21 L14 glide
o
Jbyer8
Current owner hasn't done a lot. Power brakes, driveline, fuel pump and lines, and replaced shocks. Aside from those items I assume nothing major has been done. It currently has a Muncie 4 speed and I believe a 12 bolt rear end .
lakeholme
New shocks won't do much good without proper springs for the weight added...
Phillip,
Do you have the weights of the 230/250 ci 6 cyl engine?   I've been under the impression the weight was very similar to a small block V8 of the same era..?
Jbyer8
the rear end and trans are original. The new drive line is sized for V8 torque. Is ok to have an original manual trans and rear end for a 6 cyl matched up with a 350 engine? Like i said no drag racing but i might want to step on it every once in awhile.
Mark
If the rear axle and transmission (12 bolt and a Muncie 4 speed) are original then it wasn't a 6 cylinder from the factory.  While you could have conceivably ordered a 12 bolt with a 6 cylinder if you ordered the right posi equipped rear axle ratio, there was no way tp order a 4 speed muncie with a 6 cylinder, it would have had a saginaw tranny originally.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Quote from: 69Z28-RS on September 23, 2013, 10:23:49 PM
Phillip,
These are rough #'s I have and Im not real sure where I got them..
Chevy L6 194-250 cid 440 lbs
Chevy L6 216/235 cid 630 lbs
Chevy small block V8 575 lbs with iron heads and intake
Chevy small block V8 535 lbs with iron heads/alum intake
Chevy V8 348/409 620 lbs
Chevy big block V8 685 lbs
lakeholme
Phillip,
Those numbers are in the AMA section of the information that the GM Heritage Center used to send.  Now, it is online. Look Here for the GM Heritage Center website and click on the Camaro links.  Mikefam posted this link a few months ago.  As I recall, the AMA info is near the end of the document, and the weight figures are near the end of that.
