69 302 dz flywheel & starter
Started by anastasios, January 20, 2010, 08:56:25 PM
anastasios
i have a number matching 1969 z28. the clutch just went on it and while changing it i noticed it has a 10.5 clutch small flywheel and the starter nose is not steel. A friend was also puzzled , we thought it would have a 11 inch clutch, big flywheel and a steel nose starter. what did they come with any help would be appreciated .  Thanks Tom
ss jim
Jerry@CHP
starter should be an 8367 with aluminum nose.
Jerry
ibfootin
My flywheel is drilled and tapped for the 10.4 inch as well as the 11 inch.  It actually had the 10.4 disc and the 11 inch pressure plate.  I went back witn both 10.4"
