Adjustable vs. Non-adjustable clutch fork pivot ball
Started by JGraft, December 10, 2022, 12:31:04 PM
JGraft
Anyone have any recommendations which type should be used and/or bad experiences with each of these? Adjustable ones are more expensive. Is adjustment capability of this item really necessary?
JGraft
CRG experts please help, I can find little to no guidance from web sources or the camaro manual I have, the info is needed for a 396 setup with a new muncie 4 speed, Hayes clutch kit, and 168 tooth flywheel.
The stock ball was good enough for GM so it should be good enough for your setup. I've had many cars over the years and never once did I need an adjustable pivot ball.
169INDY
68 SS/RS L35 Th-400 LOS
69 Pace Car L48 Th-350 LOS
68 Z28 M21 LOS
