68 Z28 Cowl Plenum fire wall pics
Started by onekidbill, April 05, 2021, 11:05:41 PM
onekidbill
Looking for any pics of the fire wall hole for a cowl plenum air system. I'm restoring a 68 Z and it has a hole where it should be along with all the right screw holes. Just want to verify.
69 Camero Z/28
68 Camero Z/28
68 Camero RS
69 Corvette 350/350  2010 Camaro 2SS
They were dealer or customer installed, I have seen one that had holes drilled across the area - and a couple which someone used a drill to out line the opening and then a chisel to break the connecting sliver. They came with a template, if you search for the cowl plenum template I am sure you will find a photo.
onekidbill
69 Camero Z/28
68 Camero Z/28
68 Camero RS
onekidbill
Thanks. That's just what I was looking for. 👍
69 Camero Z/28
68 Camero Z/28
68 Camero RS
