Wheel and tire advice needed
Started by x44d80, January 20, 2019, 09:15:06 PM
x44d80
I really like the look of these tire and wheels on this car for sale on Ebay.  Any guess on the front and rear rim size?  Thank you in advance.
Brent.  https://www.ebay.com/itm/1969-Chevrolet-Camaro-SS-RS/333026068554?hash=item4d89e6884a:g:qYcAAOSwbWJcQTRb&vxp=mtr&redirect=mobile
69 Zee
Yeah... 15 inch  (tires are G60-15)
Darrell
'69 Camaro Z/28: 03B NOR X77 Dusk Blue, white top, all orig, Under construction
'70 Plymouth Superbird: One owner, Limelight green, 45K miles, all original U code
ZLP955
Yep, those tires are F60-15 front and G60-15 rear, so wheels are probably 15x7 - they look like Torq Thrust Originals to me.
Tim in Australia.
X33RS
It's the same wheel I currently run on our RS Z.  15x7 with 3.75" backspacing.  I can tell you though the F60's up front don't clear the upper front fender lips or the plastic covers for the headlight door actuators if the car is sitting at it's stock ride height.  An F70 will work but it's close.
x44d80
Thanks all.  I didn't know if they were 15x7's or a mix of 15x7 front and 15x8.5 rear.
ZLP955
Those rear wheels could be wider, as tire manufacturers specify the recommended minimum and maximum bead width for each tire to make sure of the correct section profile and contact patch.
Best way to be sure - send the ebay seller a message asking if he/she can confirm; as the wheels/tires don't go with the car, they're probably new-ish, or borrowed.
Tim in Australia.
x44d80
That's a nice car there.  Sold me on that rim and tire combo.  Thanks all.
BLACK RS/Z's with endura's photograph so well... I miss having it as a model more than I miss driving it.
The offset looks different front to back on the ebay car. I too think the rears are wider.
X33RS
On the back I'm willing to bet they are the same 15x7's.   The only wider wheel in this style is 15x8.5 and they only come with the same 3.75" back spacing.  So the extra 1.5 inches is towards the outside.  They don't fit on the 69's very well because it pushes the tires out past the wheel well lips.
Even the 7's are tight back there.  On mine with a 255-60-15 (equivalent to the G60's you see in the picture) I can't even get a finger between the tire sidewall and the wheel well lip......it's TIGHT, but it works without rubbing.  There is no way a 15x8.5 is going in there at a stock ride height without tearing up the tire or the quarter.
