torque sequence
Started by sebastien, May 20, 2007, 08:28:55 PM
sebastien
what is the proper torque and sequence for a small block cast iron intake manifold and original exhaust manifolds?
also,is that correct that there is no gasket betwwen the heads and the exhaust manifolds?
Sebastien 68  327 rag top
dab67
Sebastien:
Let's see if this comes out correctly. Sequence for SBC Intake. I have nothing on the exhaust.
Dave
dab67
Sorry it will not load, wrong format,
Looking at engine from front
Right Side(Passenger) sequence numbers are  12,11,4,1,5,and 6 for the very back
Left side(Drivers) sequence nmbers are 10,9,3,2,7 and 8 for the very back
30 pounds torque with oil.
Hope this helps
Dave
Sebastein -
All this info is in the factory Chassis Service Manual & Chassis Overhaul Manual, which can be purchased at most first generation Camaro part retailers.   :)
sebastien
ok thanks,I have the chassis manual.iI'll double check.
Quote from: sebastien on May 20, 2007, 08:28:55 PM
Correct - no Chevy V-8 ever used exhaust manifold gaskets, although the aftermarket gasket manufacturers seem compelled to include them with their gasket kits.
