De-rusting my drive shaft... What to preserve it with??
Started by 69Z28-RS, December 05, 2015, 12:15:27 AM
Quote from: 69Z28-RS on December 05, 2015, 01:00:26 PM
Quote from: Mike S on December 05, 2015, 04:50:32 AM
Gary,
I've been using RPM (Rust Preventive Magic) from ECS on parts I leave natural such as steering linkage, coil springs and manual steering box
and will use it on the drive shaft too.
Hello Mike,
I've never used/heard of this product, but googling finds me this..  Is this the exact product you purchased?  Is it available in other quantities that you would recommend instead of the 8 oz size?   From the description, it sounds perfect, but I'm skeptical usually of marketing claims.. :)
http://www.amazon.com/RPM-Rust-Prevention-Magic-oz/dp/B00ITVG8IK/ref=sr_1_1?
ie=UTF8&qid=1449338167&sr=8-1&keywords=rust+prevention+magic
PS.  Thanks to everyone who made suggestions.  I have some Boeshield but haven't used it enough to be a proponent as yet.
Hi Gary,
  Yes, that is it. I don't know if it comes larger but the size shown will cover probably a few cars worth of raw metal. I use a small painters brush to apply it. My resto too is mid-stream so I'll see how the RPM holds up to the steering box heat exposure. The linkage and springs were done 2 years ago and stored in an unheated basement and no rust developed. I applied it after glass beading the parts so the pours were freshly filled by that product. My thinking is that for parts that do get hot enough to have the protectant lose its efficiency, then they probably will have to get touched up.
OK..  I left my driveshaft in the 'derusting chamber'.. :) .  for a couple hours more than a day.   Since the temp has been around 60 daytime and 35-45 at night, I thought a bit longer would be OK.   What I found when I removed the driveshaft from the tube was a totally cleaned, almost 'blackened' driveshaft with paint stripes showing; orange and white adjacent and then a bit apart was a yellow splash.   I should have photographed it before running water over it..  as when I did (even without any force) the orange/white paint began to run .. so I stopped with the 'washing' and took the first photo.
I stopped washing down and resorting to 'wiping only the unpainted areas with a wet cloth'.. then dried using an old hair dryer  I then applied a lite coating of 'Metal Rescue -Stop Rust' over the painted areas.  last photo.  I don't plan to repaint the stripes; I'm thinking enough of the original strips will be visible to show originality on my unrestored car.  I will apply Boeshield (when I find my supply).. :)  to preserve it as much as possible.
I measured from center to center of the driveshaft mounting rings and got 49-5/8" as closely as I could read it.
thanks Daryl,
I was a little surprised (and disappointed) that the Evaporust was dissolving the paint.. I've left other partially painted items in Evaporust and Metal Rescue for much longer periods without affecting the paint.  I can only conclude that the 'paint globs on driveshafts' were not done with a high quality paint.. and were probably applied to a greasy driveshaft (new metal).. with no intentions of the paint lasting for 46 years.  As I said, I left the driveshaft in the solution in approx. 60 F temps for maybe 26-27 hrs, so anyone doing this in the future, might try shorter periods (maybe 12 hrs?) in hope to better preserve the paint strips.  Too bad they don't make 'clear' PVC tubes in 4" ID..  :)
6667ss138
Yep, good work Gary! I look forward to doing mine in the future. I will follow your advise on soak time.
What's the distance of the stripes to a u-joint and which one?
Quote from: KurtS on December 06, 2015, 09:25:24 PM
The orange stripe was approx. 12 inches from the Yoke joint.
The white stripe was approx. 3/4" farther away from the yoke joint.
The yellow splash of paint was approx. 21-22 inches from the yoke joint.
Quote from: Mike S on December 05, 2015, 01:43:45 PM
Gary,
Hello Mike,
Hi Gary,
Mike, I would not use the RPM on anything that will or could be heated up substantially. I've been using on many parts for several years and found it does not work well on smooth parts and is best on castings and screw/bolt/nut parts. Mentioned this several times but a NCRS judge friend got me on Quanta gas tanks rust prevention dry. That stuff is just Great and easy to use.
Gary, your chamber looked exactly like what I did and posted a few years ago. It would be possibly beneficial to add your info to the drive-shaft thread with the dimensions for future reference and searches. It's fun is it not? :) For anyone doing it a 5' long piece of 4" tubing capped, install that drive-shaft and exactly 2 gallons of evapo-rust emerges the shaft. Had mine in for 24 hours and amazing what can be found. I've done three drive-shafts (68Z, 69 std v8 Camaro, and 67 corvette) and all three have had distinctive paint markings.
Quote from: 68camaroz28 on December 09, 2015, 08:21:35 AM
Chick,
I followed the directions I found from previous posts here in CRG to derust the driveshaft, but I can't tell you if it was your post or someone else... Maybe you were the first to do this?  (you should have patented it!) :)
Because it was cool the day I did it, I left mine in for about 26-27 hrs, yet with gently running water, the paint marks immediately began to run..  so I'm thinking that was too long a time.  Next time, I'll check after 12-15 hrs and see what I've got.  I'm not *restoring*, but just preserving, so I will not redo/add paint... so I was disappointed that most of the factory paint ran off with a light water bath...
I'll have to check out your suggestion for Quanta gas tanks rust prevention dry..  not familiar with it at present.
HawkX66
Quote from: 69Z28-RS on December 09, 2015, 08:55:59 AM
The same thing happened with my brake hardware. All the nice legible markings washed away after I pulled it out of the solution.
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
That would indicate they are water-soluble paint. Not much you can do about that....
Chick,
Here you go Gary and again this stuff is good!    http://www.gastanks.com/RestoGuard-Dry-All-Metal-Protector-Lubricant-12-oz-spray-can/productinfo/05-11/
I need to find it for sale somewhere...  12 oz spray can is $16.95.. and SHIPPING IS $16.31.. (I don't think so) *G*
Quote from: 69Z28-RS on December 06, 2015, 10:47:06 PM
Not to change the course of the thread, but only to add to the striping color/location. I could clearly see the distinct lines on this D.S. out of a 69 P.G. 6 cyl. I carefully cleaned the area and what do you know?, it is orange & white, like Gary's. This D.S. along with my 2 big block 4spd and 1 turbo 350 and 307 appear the same in length, offset & yoke.
