Racing shock absorbers
Started by Jon Mello, March 03, 2011, 10:41:01 PM
Bruce302
Great thread Jon,
I have one of the rear shocks off my T/G Firebird. It seems to have a GM part number, 9791594
with a date code of 4/67 (Must have been some old stock they had sitting around)
They are single adjustable of course with Koni number 80 1915 SP1
I will have a look at the front when I can dig it out.
Thanks, Bruce. That's very interesting that your car was using a shock meant for a '67. Did it also have the '67 style shock plate under the leaf springs?
Bruce302
I'm not sure Jon, I will have to acquaint my self with the different style shock plates. Or post a pic.
Bruce.
Bruce, the '67 style plate has a separate bolt that slides through two holes on either side of the shock and the '68-'69 multileaf plate has a single threaded stud (bolt) that is attached to the plate. The shock bottom slides over the stud and you tighten the nut down on it. If you still can't visualize what I'm trying to describe, I'll look for some pics.
Bruce302
Jon, My lower spring plates have a turned down 'ear' that the shock bolt passes through on the inner side (staggered shocks) The bolt is firmly in the lower shock hole and the nut is under the spring plate.
I will take a pic.
Bruce.
Bruce302
Looks like the 68-69 version of the sprint plate Jon.
Bruce.
OK, thanks for the confirmation Bruce.
70L34
I came across a pair of 1970 vintage Konis with part number 80-1217. I can't locate this number in any vintage or modern Koni catalog I've been able to find. If anyone can assist I'd sure appreciate it!
crossboss
1968 Olds 442 W-30
70L34
Wow, thank you for that! Definitely do not have one of those in the garage.
crossboss
Quote from: 70L34 on May 24, 2023, 08:22:25 PM
You are welcome! Actually, a good friend has a '63 Ferrari 250 with a 275 front clip.
1968 Olds 442 W-30
BRG Z28
1967/68 Chevrolet original Koni shocks
BRG Z28
Original Chevrolet Koni boxes
BRG Z28
