My New '68 Camaro Z/28 Butternut Yellow
Started by dannystarr, July 17, 2014, 02:17:20 PM
dannystarr
Drive line markings. Had a hell of a time getting something to show up color wise. Looks like 4 stripes ... Orange - Yellow - Orange - Yellow
dannystarr
Interior is very nice... Windows were down for who knows how long. Hours and Hours getting the inside cleaned. Carpet showing wear at drivers feet side and fading throughout. Looks to be all original. Headliner, Door Panels, Dash and all seats nice. Couple small cracks in drivers door handle top pad. No other damage... Danny
NOTE; I have detailed pictures of factory carpet cuts under seats if needed.
dannystarr
dannystarr
dannystarr
dannystarr
dannystarr
dannystarr
dannystarr
dannystarr
dannystarr
dannystarr
dannystarr
Forgot to post these other trunk angles...
dannystarr
Original front and rear carpet tags..
dannystarr
 Jano - Steve- As you can see the muffler at tailpipe is welded, and I think all the exhaust is original.
  All three of the rubber brake lines are changed. Will do Trans, Rear and Steering box fluid. Steering box is weeping oil, is there a sealer to add for now?? Will mic out the rotors and drums for thickness safety .
  Belts and radiator hoses along with heater hoses not original. So changed it all out. Except heater hoses, left those looped for now, until I do the heater core this winter.
  Fuel line back at the tank has been changed along with the clamps. Keep all old stuff...
  Carb not sucking air at base, neither is manifold. Carb just needs work. I put a rag over the carb primaries and the engine dies in a half of second.
  Tim - ZLP - Trying to get the money together for fuel pump, and carb rebuild, that's about 3 or $400 I don't have right now.
  BCMiller - Did you see the extra holes in the deck lid you were talking about? Do you need better closer pictures?
  Jerry G. - Pictures of PCV coming right up. NOTE it is purple, just like the one everybody said was not correct. But maybe not original, I shook it and it is loose, probably going to leave it, or no??
  HOTROD68 - TOO funny, yes I guess that horseshoe jumped up my butt on this one eh? Good times!! I notice you have yourself a nice butternut yellow ride. Give me 40K and you can have mine.. ha ha
