Author Topic: Identifying an L30 from an LF7 engine? (1967)  (Read 3544 times)
67L48
« on: July 27, 2022, 02:26:34 PM »
I have read the reports on the L30/M20 combo.  But, that's not what I'm interested in.  How would a person identify an otherwise garden-variety L30 327/275 apart from an LF7 327/210?  For example, what if a car had an M35 Powerglide transmission and a 327 engine.  Do you have to pull casting numbers to identify the type of 327 or is there another way to determine this?  Perhaps valve covers, air cleaner, some obvious marking somewhere, etc.?
In case there are year-to-year variances, I'm most interested in the 1967 model year.
Thanks.
67L48
1967 Camaro SS 350
PG, factory air, console, fold down rear seat, PS, PB, butternut yellow, #s matching, original manual/warranty/POP, <60K miles
Northeast Iowa
Re: Identifying an L30 from an LF7 engine? (1967)
« Reply #1 on: July 27, 2022, 02:54:25 PM »
The LF7 came with a 2BBL carb and the L30 came with a 4BBL carb. But here's the best way, check the suffix code on the front pad. That'll tell you exactly what engine it is.
Gars68Tux
Garth
68 RS L30 AA 749 Fred Gibb Chevrolet
67L48
« Reply #3 on: July 27, 2022, 07:04:39 PM »
OK, to my eye, this image looks like what I see in that eBay ad and, therefore, an L30:
67L48
1967 Camaro SS 350
Northeast Iowa
« Reply #4 on: July 27, 2022, 07:12:09 PM »
You can't go JUST by the casting symbol. Heads are easily replaceable so what's the suffix code on the front pad?
Gars68Tux
« Reply #5 on: July 27, 2022, 08:13:45 PM »
Yep, COULD be an L48  :) as they had/have the same block(casting) and heads (as the L30). The suffix code on the pad http://camaros.org/drivetrain.shtml#PadStamps will determine the block originality and what heads were installed from the factory.
Garth
67L48
« Reply #6 on: July 27, 2022, 08:57:29 PM »
No idea and I won't really find out.  This just came up on a Facebook chat.  Someone posted this car and some pics, stated it was a 327 owned by an old lady. Another guy stated it might be an L30 327/275.  That's when I discovered that I had no idea how to even identify such a thing (without, of course, pulling castings and other block ID #s).  So, I was just wondering if there was an easy way to visually see whether a 327 was a 210 or a 275.
Completely trivial question.  I was just wanting to learn more about how to visually identify the differences between the engines (or if it were even possible).
Thanks.
67L48
1967 Camaro SS 350
Northeast Iowa
Gars68Tux
« Reply #7 on: July 27, 2022, 09:06:57 PM »
Well, if it was an LF7 (210 hp), it's not anymore, because of the double hump heads. The bottom end (from the heads down) of an LF7 and L30 are identical.  It likely is an L30 from the photo and description.
Garth
