Author Topic: 300 HP 350 block 19N552258 T1120HA  (Read 6636 times)
Hindu
« on: July 23, 2014, 01:29:54 AM »
I recently came across a 300 HP 350 block from a 69 Camaro 19N552258 T1120HA.  It has a casting date of K18\8 and a casting  # 3982338.  I would like to know if
someone could tell me if the car is still out there.  The block has been sitting in a garage for the last 30 years.  When the engine was removed the car was known to have been in the Chicago area.
« Last Edit: July 23, 2014, 02:39:22 PM by Ed Bertrand »
Boston14
Re: 300 HP 350 block 19N552258 T1120HA
« Reply #1 on: July 27, 2014, 09:24:26 PM »
I believe the casting number should be 3932388.  My engine was also built in Tonawanda on 1120 except it is an HB (automatic).  My vin is very close to that one.
boston14
1969 SS/RS 350 Convertible
Hindu
« Reply #2 on: July 29, 2014, 12:22:11 AM »
Thanks for the update.  I am sure you are correct.  That number was questionable.  When I am able to get to to the block I will verify  that and edit the post.  Thanks again.
Hindu
« Reply #3 on: August 04, 2014, 05:28:27 PM »
http://  Yes you are correct.  I rechecked the casting # and it is 3932388.  Thanks again for your help.
