Author Topic: Stripe delete  (Read 83001 times)
bc69
Stripe delete
« on: May 01, 2014, 09:03:43 PM »
Anybody ever encountered a car that had a factory stripe delete
order in its history?
Brad
RSSS
Re: Stripe delete
« Reply #1 on: May 01, 2014, 10:08:34 PM »
No 1 owner of my 68 said it was ordered stripe delete. Also no console.
bc69
Re: Stripe delete
« Reply #2 on: May 01, 2014, 11:16:47 PM »
Do you have any documentation referring to it? If so what kind and how does it refer to it?
Brad
RSSS
HOT3O2
Re: Stripe delete
« Reply #3 on: May 02, 2014, 12:25:38 PM »
Yes, My car was ordered without stripes. It's marked on the build sheet as: (Stripes to be deleted). It also has the special paint code (-) on the trim tag.
Rick
69 RS/Z28
bc69
Re: Stripe delete
« Reply #4 on: May 02, 2014, 01:25:47 PM »
How is the (-) placed in the tag?
Brad
RSSS
HOT3O2
Re: Stripe delete
« Reply #5 on: May 02, 2014, 01:31:39 PM »
It takes the place of the paint code.
Rick
69 RS/Z28
bc69
Re: Stripe delete
« Reply #6 on: May 02, 2014, 01:38:50 PM »
Do you have a pic of tag? I have a 67RSSS that is said to be a factory bb delete.
Looking into a little more verification.
Brad
RSSS
Re: Stripe delete
« Reply #7 on: May 02, 2014, 02:41:59 PM »
This is true for late 68 & 9.
67 would have been 0-0 & early 68 would have been Z-Z
http://camaros.org/numbers.shtml#CowlTag
Scroll down till you get to - Cowl Tag Examples for Special Paint
Just post a pic of your trim tag and we will be able to help you.
bc69
Re: Stripe delete
« Reply #8 on: May 02, 2014, 03:18:57 PM »
Paint code shows A-2. So  your saying A= lower tux black, - = delete, 2 = vinyl top.  ??
Brad
RSSS
bc69
Re: Stripe delete
« Reply #9 on: May 02, 2014, 03:31:21 PM »
Scratch that question. I finally found the CRG section on this. I have no dash on tag after options or on lower section.
Brad
RSSS
Re: Stripe delete
« Reply #10 on: May 02, 2014, 03:36:15 PM »
Quote
If you mean by "bb", a big block, there's no such thing as "big block delete". The 396 was an option, like a radio or power steering. It wasn't "standard equipment" and you can't "delete" options.
bc69
Re: Stripe delete
« Reply #11 on: May 02, 2014, 03:41:51 PM »
Stripe Ed....Bumble B.
Brad
RSSS
Re: Stripe delete
« Reply #12 on: May 02, 2014, 03:42:46 PM »
Ah! That makes more sense.
Re: Stripe delete
« Reply #13 on: May 02, 2014, 04:43:15 PM »
Here's one example from a LOS special paint cowl tag...
Re: Stripe delete
« Reply #14 on: May 02, 2014, 06:41:13 PM »
looks like that was the only thing special about it, when you found it!
