Main Menu
1967 Camaro radius rod research
Started by KurtS, January 23, 2010, 10:04:17 AM
Previous topic - Next topic
I just updated the radius rod article with pictures that Ronald and David and David and Jared have sent me over the past few years. Some really nice shots of the axle brackets and now the floor bracket.
Photo credits appear when you hover your mouse over the picture - I think I got them all right. :)
http://www.camaros.org/radiusrod.shtml
Thanks guys!
Petes L48
Just spotted this 12A LOS L48 w/ PG on eBay.  States that it has the round radius rod but no pics or axle code.  From the ad:
"Front Disc brakes, 12 Bolt Posi, Round Radius Rod, R/S hideaway headlight assembly with relay board and wiring harness"
http://www.ebay.com/itm/Chevrolet-Camaro-Rally-Sport-Super-Sport-1967-camaro-rs-ss-350-/251483478160?forcerrptr=true&hash=item3a8d955890&item=251483478160&pt=US_Cars_Trucks
1967 RS/SS 350/295HP CAMARO
Clean California Title.
VIN: 124377L127692
COWL TAG:
12A                             M034
ST 67-12637 LOS-11557
TR 765-Z                  Y-2
      W 2MG 3L
      4P    5Y
x77-69z28
Kurt, you have the info on my car. I bought it from the original owner in 1984. It is an L48 m-20, 3.73 car. The original owner states that the car was recalled to install the radius rod. It is square, and they didn't use the brkt under the rear seat. There are two bolts and lock washers holding the front radius rod brkt.
 There should be 3 bolts holding the front bracket. Two against the floor and one to the side rail.
Pete,
That car was on ebay 2 years ago - same condition. I think that's a very early car.
Buddy,
Thanks, so noted.
luv2sixty9
Does anyone know why or when the change of the axle bracket came to play on the Second Design - Rectangular Radius Rod. I've seen two versions, one have a press mark and the other having a hole drilled just above the side dimples? I'm surmising a June of 67 change.
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
Quote from: luv2sixty9 on May 21, 2014, 09:46:40 AM
I assume the square was needed to handle the larger engine torque and also the additional snubber bracket added as a means to limit the rears travel due to spring wind. As for a transition period I don't know when. We can only get a rough approximate from the dates within the assembly manual but that's not exact when it hit the production floor.
 The two Camaros I have with original rears are one 'BJ' rear (3:07) stamp dated 0404 for a LOS 4B (April 13th per UOIT) dated trim tag and that has the round bar with no holes provisioned for an additional bracket. That car has the L35 w/TH400. The other rear is a 'QK' (3:31) stamp dated 0331 for a NOR 5B dated trim tag and that has the square bar with the additional bracket for the snubber. That car has the L35 w/4 speed.
luv2sixty9
Mike,
Thats not what I'm asking. I'm referencing cosmetic looks on the bracket welded on the axle tube for the square bar.  I've seen some with press marks and another with a hole on the backside of the bracket. It can be viewed on this link       http://www.camaros.org/radiusrod.shtml
1969 RS SS Pace Car
luv2sixty9
On the lower pictures; first picture you can see the circular press marks just below the side notches. And on the last picture you can see the factory hole just above the side notches. Thats what I'm asking about.
1969 RS SS Pace Car
 I see the hole now....its dark in the picture where you can't notice it unless you know it's there.
I'll check my car when I get home to see if it has that lone hole in the back.
 Here is a picture of the 'BJ' rear dated 0404 on the '67 04B LOS L35 w/TH400 transmission.
This has the round radius rod and you can see this has the hole in the rear.
I looked at the 'QK' rear dated 0331 and this has the square rod w/stop bracket. There is no hole on that axle tube bracket.
It would be interesting what the hole was for. Maybe to hold and/or strategically place the bracket on the tube prior to welding?
Could be an interesting poll to add to the CRG article.
Maybe something like:
Date   Code     Radius Rod        Rear Hole
                   Round/Square         Y/N
___________________________________
0331   QK        Square                   N
0404   BJ         Round                    Y
luv2sixty9
Yes, it would! Come on guys let us know..
1969 RS SS Pace Car
0126  QL     Square      No hole
0303  PJ      Square      Hole
Sorting on date:
                    Round/Square         Y/N
0126   QL         Square                 N
0303   PJ          Square                 Y
0331   QK         Square                 N
0404   BJ          Round                  Y
Jon,
  First, thanks for adding to the research.
I think I see a pattern already between the bracket with the hole vs. the one without it.
From what I see in the CRQ report pictures and on my 2 cars is the one with the hole also has a stepped 'notch' in the very rear of the bracket on the bottom.
The bracket without the hole is flat along that rear edge. Can you confirm if yours are that way too? That would make it sound like there were possibly two suppliers of that part or a change in the way it was stamped and no other meaning for the existence of that hole.
Thank you,
