Main Menu
Preservation of a 68 Camaro
Started by cook_dw, December 01, 2021, 08:09:31 AM
Previous topic - Next topic
Photos 552 - 553 - Gas pedal and throttle arm.
Photos 554 - 555 - Next were the Astro Vent duct work and the bezels & balls
Photos 556 - 558 - Using my Harbor Freight special da polisher I run over the dash face with some Mequiars 105 since I had previously had #7 soaked into the paint prior.  Note the lack of paint in and around the knob areas.
Photos 559 - 560 - Installation of the drop down brackets, pedal assembly.
Photos 561 - 562 - Clutch rod along with its boot.
Photos 563 - 565 - Dimmer switch, ignition, headlight, wiper and cig lighter switches installed
Photo 566 - Shot from the outside of firewall. Also installed correct 4 rib washer nozzle hoses.
Complete steering column teardown and go through hopefully in the next couple of weeks.
Photos 567 - 568 - Close up of the control knobs.
Photos 569 - 571 - Cluster installed. First time since the late 70's
Now that the defrost duct, heater box, controls & radio are now in I touched them up from all the handling.  303 is the product I'm trying on the duct work.
Photos 572 - 575 - Under dash area passenger side compartment.
Photo 576 - Glove box door after hitting it with Mequiars 105 on a maroon pad on my da polisher.
Photos 577 - 578 - Dash after controls & radio installed.  Also a sneak peak at the trio of gauges I'll be installing into the car as well.
Photos 579 - 580 - Mounting some accessories.
Great work Darrell and detail to assist others......
