Main Menu
carburetor date
Started by lilfighta, February 13, 2017, 05:20:32 PM
Previous topic - Next topic
lilfighta
Hello could someone tell me how many months prior to a car being built is the carb date. For example if car was
built in june 1968 would a February or March be correct. Also what carb came on car rochester or carter. Or you need the build sheet
thx mike
Quote from: lilfighta on February 13, 2017, 05:20:32 PM
thx mike
Mike, Carter carburetors were not available on Camaros in 1968...
http://www.camaros.org/carb.shtml#usage
lilfighta
Paul I believe they were. Im mostly interested in date factor. The time factor
thx
lilfighta
Why do you say amazing? Because i said they were available ?
x66 714
I thought Carter was building Q-jets for a while or am I mistaken?...Joe
lilfighta
The story was when rochester couldnt supply enough to gm carter was building them and they did build them for awhile and if i remember they started in 1965 - 1970 i think dont hold me to the exact dates. Does anyone know about the date codes for june 1968 camaro
carburetor
thx
Carter built Quadrajets were built and used for many years - including 67-9.
>However, Carter was also licensed to build the Quadrajet as a secondary source, and supplied carburetors to not only Chevrolet, but other GM divisions as well.
June car probably had a May or June carb on it (depending on when in June).
 Both of my '67 L35's (04B & 05B) have their original Carter made Quadrajets.
Carb for June car, yes most likely dated in May. Early June carb possible if car is a late June build.
lilfighta
Thank you KurtS and Mike. A friend told me that it is possible that you can use a carb built
in March or April also. He said you can go back as far as 2-3 months just trying to clarify this.
THx
lilfighta
Kurt S carter used the carbs on alot of chryslers also same years.
lilfighta
LOL I forget where does it tell your car has a carter or rochester. Is it on the POP or on the build sheet
Alot of questions from 1 guy eh kurt LOL
Quote from: lilfighta on February 14, 2017, 10:48:17 AM
THx
My thinking the date depends in part of the engine popularity so I'm sure the carb date would vary.
