69 Z/28 X77 garage/barn find
Started by 69 Zee, August 09, 2014, 10:37:28 AM
Darrell,
Are there any ribs running the length on the vacuum hoses?
69 Zee
Quote from: Mike S on September 22, 2014, 10:27:11 PM
Darrell,
Yes there are Mike
Darrell
'69 Camaro Z/28: 03B NOR X77 Dusk Blue, white top, all orig, Under construction
'70 Plymouth Superbird: One owner, Limelight green, 45K miles, all original U code
 When you get time could you post a picture of the ribs?
Thanks!
69 Zee
Quote from: Mike S on September 22, 2014, 10:47:32 PM
Thanks!
Yes, I'll post tomorrow afternoon when I get home.
Darrell
69 Zee
Darrell
good pics. I know they make the rubber hose with the white line on it, but do they make it in a ribbed style?
69 Zee
Quote from: BULLITT65 on September 23, 2014, 05:16:09 PM
This hose has both, ribbed and white on the other side.  See pics on pg 17
Darrell
I understand, just wanting to know if it is available still.
Great pic....how many raised ribs? I have a reproduction from LI Corvettes and on this repro I count 7 raised ribs.
69 Zee
Quote from: Mike S on September 23, 2014, 06:22:24 PM
Only 3 raised ribs
Darrell
69 Zee
The original Brake Booster Hose Bracket
Darrell
69 Zee
Plug Wire Stands.  Looks to have been painted once before. Guessing when the block was repainted.  Is that a typical stamp mark in the smaller stand ?
Darrell
69 Zee
Darrell
69 Zee
Throttle Rod and Adjustable Sleeve.  A little TLC on all these parts and we'll be good to go   ;D
Darrell
