Main Menu
What small block is this
Started by aaberg, June 02, 2025, 06:20:13 AM
Previous topic - Next topic
aaberg
In my Camaro 1968 I assume having a service block installed. Great if someone can help mee find out what engine this is. Thank you!
Stamped: V0202TDL
Cast: 3970010
x66 714
I see TDL listed as a 1980 350 4 brl for a C20. 155 hp.....Joe
boomer632
TDL could be
1972 307 2BBL automatic
1980 350 4 BBL automatic
06A X66 711 57 57 M22 BU
x66 714
Quote from: boomer632 on June 02, 2025, 06:37:37 AM
TDL could be
Not with an 010 block. That's a 4" bore casting. The 307 is smaller bore & wouldn't use that block. I almost said the same thing....Joe
aaberg
Perhaps not true, but I asked answers.com and got this. True?
Stamped Code: V0202TDL
V: Indicates the engine was produced in the Flint, Michigan plant.
02: Refers to the day of the month the engine was built (February 2).
TDL: This is the engine suffix code, which indicates specific details about the engine configuration:
T: Typically denotes a truck engine.
D: Indicates it is a 350 cubic inch engine.
L: Suggests it was used in specific applications, often related to heavy-duty uses or particular vehicle models.
Cast Number: 3970010
This casting number is associated with the Chevrolet 350 engine block, produced from 1969 through the early 1980s. It is a common casting used for various small-block applications.
boomer632
I pulled my information from the lime book
Quote from: aaberg on June 02, 2025, 08:24:36 AM
False. Joe's answer is correct.
