Camaro Research Group Discussion => Restoration => Topic started by: erik67ssrs on July 21, 2006, 09:54:02 PM
Title: Original style exhaust system for 67ssrs?
Post by: erik67ssrs on July 21, 2006, 09:54:02 PM
I have a 67 ssrs which is mostly original, including the engine 350/295.  My exhaust system is wrong and I want to replace it with an original style (transverse muffler) system.  Any comments on brands, fit, quality of aftermarket exhausts would be appreciated.  I don't want anything too loud, nor anything too quiet (I know these are subjective).  I have heard D&R and Walker sell good replacements.
Title: Re: Original style exhaust system for 67ssrs?
Post by: rich69rs on July 22, 2006, 04:03:36 PM
Last year I replaced the dual exhaust that was on my 69 RS with a stainless exhaust manufactured by Stainless Works and purchased through Summit Racing.  Very nice system.  The tail pipe from the back of the wheel well area is polished chrome over the stainless.  This particular exhaust system was designed by Stainless Works to be a bolt in replacement for the original and was designed to bolt up to stock exhaust manifolds.  I also believe they make a system(s) for header applications.  Unit fits nice under the car and mated up well with the hanger locations.  Pipes are mandrel bent.  Muffler is not loud, but is not stock quiet - I was looking for a little throatiness and it sounds pretty good.  Standing behind the car you wouldn't suspect a base 327 under the hood.
Pic shows fit of transverse muffler and tail pipes with the polished exhaust tips.
Post by: x77-69z28 on August 16, 2006, 12:57:48 PM
i just got a gardner exhaust system for my 67 rs/ss. i am in the middle of a frame off and haven't started it yet, but the quality is amazing. they are exact reproduction pieces. check out their website at www.gardnerexhaust.com.
Post by: firstgenaddict on August 17, 2006, 01:16:57 AM
There is nothing like a Gardner system... they fit with no cutting, bending, hammering, etc...
Post by: jeff68 on August 17, 2006, 03:00:55 PM
I have a Stainless Works system that I purchased many, many years ago.  The fit was perfect and it is louder than stock, but not too much.  If you are looking to go stainless, I would suggest this system.
Post by: dans67camaro on October 15, 2006, 05:43:37 PM
I had a 67 SS/RS in 67. The correct system would have had 2 seperate runs (true dual) from the exh. man through to the transverse muffler. However, there were 2 resonators in the system just before the pipes went over the rear the axle, on either side of the driveshaft. I believe Ground Up Restorations sells such a system, with and w/o resonators. I'm restoring my 67 and plan on going with the resonators. Good Luck!
