Camaro Research Group Discussion => General Discussion => Topic started by: tmodel66 on March 08, 2012, 12:26:16 PM
Title: Distributor Weights and Springs
Post by: tmodel66 on March 08, 2012, 12:26:16 PM
'69 L48 4 speed. I bought a used distributor and I think somebody has tinkered with the weights and springs. Where can I buy a new set of weights and springs to put it back to stock performance?
Title: Re: Distributor Weights and Springs
Post by: L78 steve on March 08, 2012, 01:47:42 PM
I wouldn't just change parts. Send it to a Dist. guy and see where its at.
Post by: Mike S on March 08, 2012, 05:17:35 PM
I have seen the springs modified and you can get stock aftermarket replacement springs with the correct rate.
What happened to the weights?
Post by: rally on March 08, 2012, 05:26:30 PM
Send your distributor to Jerry MacNeish. He can fix all your issues, great workmanship.
Post by: tmodel66 on March 08, 2012, 07:59:23 PM
Quote from: 67-Z27 on March 08, 2012, 05:17:35 PM
One spring broke and I got to looking and the weights have been ground on.  I was hoping to get a set of Delco weights and springs but I can't find any at the parts house.
Post by: Marty on March 08, 2012, 11:04:19 PM
Used distributors at swap meets are $5-10. Maybe cheaper to do that for parts. Martin
Post by: tmodel66 on March 08, 2012, 11:18:12 PM
Thanks Marty !  Hadn't thought about that. I think I know where one is at right now.
Post by: JohnZ on March 09, 2012, 10:44:34 AM
Quote from: tmodel66 on March 08, 2012, 07:59:23 PM
Weights and springs haven't been available from GM for over 20 years; most guys who have Sun machines and rebuild distributors (like Jerry M.) have a stash of them. The weights in aftermarket "kits" aren't hardened, and they usually only have three generic types of springs. As Marty noted, used distributors are the best source of GM weights and springs.
Post by: Mike S on March 09, 2012, 11:20:15 AM
Quote from: JohnZ on March 09, 2012, 10:44:34 AM
I wasn't implying that they can be had from GM. But with today's gas quality, low octane and the absence of lead, the stock spring rates are a moot point for driving so using a modified rate to change the curve profile will likely change the springs anyhow unless the intent is to have museum piece.
Post by: KurtS on March 09, 2012, 02:38:29 PM
Agree, you don't want the stock springs in there. Way too slow of an advance curve.
Post by: tmodel66 on March 10, 2012, 11:59:42 AM
Quote from: KurtS on March 09, 2012, 02:38:29 PM
I was just needing something to put in it to get started. Then I'll map my advance and set it up to my engine. I know I'll have to change the springs because I'm running a small cam.
Post by: 1971ls6 on March 10, 2012, 08:23:42 PM
Go out and buy the mr gasket 927 spring kit and use one gold and one silver spring, this should give you all of your advance in by 2500-2800. The weights in the kits are not good, look for a set of original ones. I tried them in all combinations on my distributor machine, and the silver and gold combo comes out as the best most of te time
Post by: tmodel66 on March 10, 2012, 08:48:24 PM
Thanks !! I got a set of weights today. I'll get on this first thing Monday.
