My '68 has 2 piece disc rottor and hub. I believe it to be original...maybe a replacement...but none the less, it is a two piece unit as the original had.
The car has sat for a very long time and as such, the wheel bearings have marked a line on the wheel bearing race. When you run your fingernail across the mark, you can feel a small indentation. I am assuming that this will wreck any new bearings I install.
Question: Are the wheel bearing race(s) removable/replaceable on these hubs? Or do I have to purchase a brand new 2 piece rottor?
I have not seen any of the more common suppliers advertise the race. Wheel bearings yes, races no.
Yes you can buy the race at most any parts house like NAPA.
Thanks tmodel66,
I did some more research and it looks loke the out bearing race is removeable, but no mention of the inner bearing race. Unfortunately, it is my inner bearing race that is scored. Is the inner race replaceable too?
Vic
All new wheel bearings come with races. Hammer and a punch to remove and replace.
Both inner and outer are removable. What i do when the old have been removed. Stick rotor in oven for 400 degrees and put bearing races in freezer. After 20 minutes i get hot glove and place rotor on bench Then put one race in place and use old to beat new one in till it bottoms. Flip rotor over and get other race out of freezer and put it in. Done. Remember metal races heat up quickly so don't waste time. Be setup before begining with all tools needed. Be careful not to strike bearing surface
Chas
