Camaro Research Group Discussion => Maintenance => Topic started by: 68Zproject on June 22, 2009, 11:00:38 AM
Title: Timing in the distributor
Post by: 68Zproject on June 22, 2009, 11:00:38 AM
Just a aclarification.  When you say I have 24* of timing in the distributor, that's just with the mechanical advance right?  Or does that include the vacuum advance as well?
Title: Re: Timing in the distributor
Post by: L78 steve on June 23, 2009, 11:57:48 AM
Right . But vac. advance is still a factor at part throttle .
Post by: JohnZ on June 23, 2009, 10:05:29 PM
Quote from: 68Zproject on June 22, 2009, 11:00:38 AM
The 24* in your example is just from the centrifugal advance system in the distributor; the vacuum advance is a totally different system. Centrifugal is driven only by RPM, and vacuum advance is driven by engine load - they're separate, but complement each other.
Post by: 68Zproject on June 24, 2009, 02:16:22 AM
The 24* was actually from one of your posts on the people trying to understand your manifold vacuum setup (which I an using on all my cars).  When you said you had a total of 36* in your distributor I was trying to make sure that you meant with initial and centrifugal.  I was an old post and I didn't want to add on that question at the end.
Post by: L78 steve on June 25, 2009, 12:03:48 PM
36* total is without vac advance .
Post by: sixt9x33rs on June 26, 2009, 06:06:46 AM
Quote from: L78 steve on June 25, 2009, 12:03:48 PM
Are you sure about that?
John Z?
Post by: Stingr69 on June 26, 2009, 09:29:03 AM
This is usualy a semantic discussion whe  ever it comes up. The best answer includes all the ignition advance information or else somebody will get confused every time. ::)
If you include initial advance plus all the centrifugal plus all the vacuum advance it should usualy add up to around 52 degrees for our old school wedge head SBC's.  ;D This would be at a high rpm cruise situation. Like driving down the highway and not under any additional load.
More advance than that is typicaly too much, and less than that may leave efficency (power) on the table.
If you want to address wide open throttle ignition advance, you do not count the vacuum advance in that calculation. Vacuum advance does not function with your foot to the floor so it does not add anything to the equation. The rule of thumb for that sum of initial plus all the centrifugal is about 36 degrees. That is the number to shoot for.
This "36 degrees" is the field you play in when you are trying to pin down the curve for high preformance, improve the idle, and have a good transition from idle to part throttle . The 2 components of this "36 degrees" are initial setting plus all of the available centrifugal advance. If your car likes it when you give it a higher initial setting, then you can increase the inital setting BUT you would want to decrese the available centrfugal advance available in the distributor centrifugal advance menchaniaism. The goal is to keep the sum of your initial plus all the available centrifugal advance equal to about 36 degrees. One goes up, the other needs to come down. You either hurt power or hurt the engine with more or less than 36.
If you follow the math you will see that the vacuum advance mechanisim is probably best if it provides about 16 degrees of advance at cruise. It just ends up that way. 36 + 16 = 52   :)
Typicaly you may find your car likes maybe 12 degrees initial advance and a centrifugal with about 24 degrees available in it. That works as a baseline for a performance ignition curve for many applications. You may need less initial and more centrifugal but the sum should remain close to 36. Bigger cams may enjoy even more initial advance. You would have to play with it to get it perfect.
Hope this helps somebody.
-Mark.
Post by: qwertyme77 on June 26, 2009, 06:55:55 PM
Mark, that is the best description of ignition timing i have ever read!! I've read magazines and books since the mid seventies and I have never had it explained so well and in so few words. Thanx!!
paul.
Post by: JohnZ on June 26, 2009, 09:07:39 PM
I've posted this on many forums over the last five years or so, to explain ignition timing, centrifugal and vacuum advance in terms that the average guy can understand, to de-mystify all the internet mis-information floating around that has it all wrong. I also published a slightly longer version as a feature article in the October/November, 2003 issue of "Corvette Enthusiast" magazine (I'm the Technical Editor). :-)
                                            TIMING AND VACUUM ADVANCE 101
                                                           John Hinckley
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren't fully-deployed until they see about 15" Hg. Manifold vacuum, so those cans don't work very well on a modified engine; with less than 15" Hg. at a rough idle, the stock can will "dither" in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15" Hg. of vacuum at idle need a vacuum advance can that's fully-deployed at least 1", preferably 2" of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8" of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don't understand it, they're on commission, and they want to sell "race car" parts.
Post by: gro51 on June 27, 2009, 07:26:25 AM
Thanks John!  That's excellent.
Post by: Oregonjam on June 27, 2009, 08:32:15 AM
Very well put. This forum is great. Thanks for sharing with us both Mark and John. It is much appreciated...
-John
Post by: Big_Al on June 27, 2009, 09:12:44 AM
Mark and John's timing explanations are the most clearest and concise descriptions I have ever read.
Kudos to you both!
I also agree with John, this forum is great!
Al
