Camaro Research Group Discussion => Mild Modifications => Topic started by: tom on March 01, 2009, 09:14:45 AM
Title: How to feed the TPI in my 69
Post by: tom on March 01, 2009, 09:14:45 AM
I am looking for a compatible tank, or internal pump assembly to feed my 69 307. TPI is off an 87 305 firebird. I have most of the system, but not the fuel pump. I am wondering if anyone has come across a factory fuel tank with internal pump that will fit with minimal effort, or if there is a GM internal pump assembly I can use with a standard 69 tank. This is a budget build, so I would like to be able to find the parts in a bone yard. I am already aware of the 1000. plus custom tanks, and will not be going that route, but could buy a repro tank to modify if needed.
Title: Re: How to feed the TPI in my 69
Post by: CVKUEBER on March 05, 2009, 04:02:02 PM
GM part# for the pump would be 25116163 or AC Delco ep241. You should be able to adapt this pump to your existing sending unit without to much fabrication. Also use strainer #25055458 or AD Delco TS4 and fuel dampener 25094266 or AC Delco FP27. This will give correct fuel pressure, However you will also need a fuel return line as well.
Post by: tom on March 05, 2009, 04:39:37 PM
CVKUEBER
Thank you!
Post by: JKZ27 on May 19, 2009, 11:04:57 PM
If its not too late, Spectra Premium industries (SPI) is making OE style tanks with fuel pumps for EFI conversions. Part number GM32BFI. Rock auto sells it for about $450. Has pump and sending unit. I put EFI in my 68 and didn't find out about this set up until after I had already run a return line through my sending unit and mounted an external pump.
John.
