Camaro Research Group Discussion => Restoration => Topic started by: CVKUEBER on December 03, 2008, 06:11:25 PM
Title: 1968 Horns
Post by: CVKUEBER on December 03, 2008, 06:11:25 PM
Does anyone have good photos of how the horns are mounted on both a 68 standard and r/s car? Closeup pictures would be helpful. The assembly manual is not to clear. Thanks in advance, Cory
Title: Re: 1968 Horns
Post by: 169INDY on December 06, 2008, 03:45:35 PM
E-mail sent with Photos of a 67 SS/RS.
Hope that it helps.
Post by: shuboxx55 on February 10, 2010, 04:23:02 PM
Did you ever get a conclusive answer, I'm presently changing an RS back to a standard grill on a 68, and I had the same question, as the book doesn' t have very good pics, and its not 100% clear whether its referring to a RS. Shows mounted on center bracket and also on the drivers side radiator support?
Post by: CVKUEBER on July 23, 2013, 02:16:15 PM
No, I have not. Still hoping someone will post pics.
Post by: cook_dw on July 23, 2013, 04:49:51 PM
Wow this thread has been risen from the dead.  Lol. Maybe this will help.
RS
(http://img.photobucket.com/albums/v687/superslow/1967%20Camaro/image_zpsc1994ecb.jpg) (http://smg.photobucket.com/user/superslow/media/1967%20Camaro/image_zpsc1994ecb.jpg.html)
Standard
(http://img.photobucket.com/albums/v687/superslow/1968%20Rallye%20Green%20396%20Camaro/DSC02528_zps29c3a463.jpg) (http://smg.photobucket.com/user/superslow/media/1968%20Rallye%20Green%20396%20Camaro/DSC02528_zps29c3a463.jpg.html)
Post by: joesauer on July 24, 2013, 09:51:25 AM
RS mounts on the center support, non RS mounts on the drivers side of radiator support.  Horns, and attached mounting brackets, are the same for both installations.  Assembly manual shows correct mounting method for both setups.
Post by: Mike S on July 24, 2013, 02:49:19 PM
 Are '68 horns mounted the same as '67? If so I can send pics from a '67 RS/SS survivor.
Post by: cook_dw on July 24, 2013, 03:08:07 PM
Quote from: Mike S on July 24, 2013, 02:49:19 PM
67 & 8 used the same horns for RS as far as I know.
Post by: DAVEN1256 on July 24, 2013, 09:00:46 PM
This is where they were on my car. I can't verify that this is the factory location, though. I had my front end apart many years ago and could not say now if the horns were put back correctly. My location differs from the photo posted by cook_dw. Maybe someone could tell me if mine were in the wrong place.
(http://i1057.photobucket.com/albums/t386/daven1256/P10100612_zps7aab53a1.jpg) (http://s1057.photobucket.com/user/daven1256/media/P10100612_zps7aab53a1.jpg.html)
Post by: cook_dw on July 24, 2013, 09:56:02 PM
According to the 68 factory assembly manual UPC 12 A8 - main shot shows the upper horn (low) & then the view B is the lower horn (high ).  Also the photo I showed of the standard headlight is an original unrestored car.
Post by: rare396bronze on July 24, 2013, 11:06:53 PM
Just verified in 67 assemly manual horns 67-68 rs are mounted on center latch support see page 426 & 427 fpr picture. Good job cook your dad trained you well!
Post by: cook_dw on July 25, 2013, 05:57:36 PM
Quote from: rare396bronze on July 24, 2013, 11:06:53 PM
