Camaro Research Group Discussion => Maintenance => Topic started by: GIBSTER on January 23, 2008, 07:24:18 PM
Title: Leaf spring removal
Post by: GIBSTER on January 23, 2008, 07:24:18 PM
It doesn't look like there is a whole lot of room to slide the bolt out of the leaf spring shackel. Has anyone had problems getting that out ?
Title: Re: Leaf spring removal
Post by: GaryL on January 23, 2008, 08:23:22 PM
You are correct, but it is commonly done. You need to raise the vehicle to let the axle hang to get the most room. Support the car at frame rails next to the front spring bracket.
Post by: GIBSTER on January 23, 2008, 08:34:39 PM
So no gas tank removal or anything like that right? I have dismantled junk cars in the past with no regard for beating up something to get them out, It's just been too many years to remember the details
Post by: dd442 on January 23, 2008, 08:45:02 PM
The top shackle bolt(and bottom bolt too) should come out towards the Outside(Quater Panel) not the gas tank,There is enough room to get it out with no problems.  Good Luck
