Camaro Research Group Discussion => Restoration => Topic started by: DAL777 on December 01, 2007, 10:00:24 AM
Title: Help Finding Part?
Post by: DAL777 on December 01, 2007, 10:00:24 AM
Anyone know where to get and or part #'s for the hose, grommet, and connector for an L-48.
It is the hose that goes from the crankcase air filter in the air cleaner assembly to the passenger side valve cover near the rear.
It is on page 101,   6  C8 in the factory assembly manual.....parts # 10, 16, and 17.  I have not seen the correct parts offered in catalogs.
Title: Re: Help Finding Part?
Post by: 1968RSZ28 on December 01, 2007, 10:45:48 PM
Quote from: DAL777 on December 01, 2007, 10:00:24 AM
http://www.classicindustries.com/
Post by: DAL777 on December 02, 2007, 08:24:00 PM
Paul,
I looked in the catalog.  All they show is an elbow and a hose.  All of the other catalogs list the same stuff.  Nobody has the connector that goes into the valve cover that the hose hooks to.
Post by: 1968RSZ28 on December 02, 2007, 09:06:31 PM
Quote from: DAL777 on December 02, 2007, 08:24:00 PM
Paul,
Dal777 -
They are there.  Do a "valve cover grommet" search and you will find them.     ;)
Post by: DAL777 on December 03, 2007, 08:56:00 PM
Still cant find the piece ("connector") that goes between the hose and grommet.
AL :)
Post by: 1968RSZ28 on December 03, 2007, 10:59:12 PM
Quote from: DAL777 on December 03, 2007, 08:56:00 PM
AL :)
DAL777 -
The "connector" (as per the AIM) I believe you are looking for can be found be doing a "air cleaner elbow" search.     :)
Post by: DAL777 on December 07, 2007, 05:53:17 PM
If you look at the picture, it is not an elbow.   (You can buy an elbow)
It is a straight piece.
Post by: 9T4Z on December 08, 2007, 08:59:02 PM
Dal..   the connector to the valve cover IS a 90 degree elbow that fits into the grommet on the pass rear valve cover.  Be careful of what hose you order.  There is a hose there for the cowl inducted air cleaner that has less of a curve to it.
You can find these parts at Ricks as well.
good luck
Post by: Camaro Billy on December 08, 2007, 09:52:40 PM
Dal,
You are correct, it is a small straight connector as it is shown on page 101 of the '69 AIM.
Here is a shot of mine, you can't see the connector but it is like the one in the AIM. I could not find anywhere to buy it repop and after about 9 months of searching I found an orig. one at  Calisle for $1.00. I know someone who found a hose at the auto parts store that matched pretty well and just cut the bottom off the 90 degree tube to make the connection.
Billy
Post by: DAL777 on December 09, 2007, 12:16:56 PM
You got it Billy!
That is the part I need.
Anybody have one?
Post by: DAL777 on December 21, 2007, 04:19:40 PM
I found the connector at a local chevy dealer.  $5.31   !!!!!!!!!
Hose and grommet discontinued in 1988.  Not available.
Post by: 9T4Z on December 21, 2007, 10:16:16 PM
Dal... oops
I have the L48 as well and assumed they were all the same.  Open element vents differently!
nice to see you found what you needed.  8)
Post by: DAL777 on January 01, 2008, 12:08:09 PM
Yea, it is just a straight
piece of pipe.  I could not
believe my local chevy dealer had
them.  I bought three!  The hose
is not available so I got a radiator by pass
hose that works great.
