Camaro Research Group Discussion => Maintenance => Topic started by: sebastien on May 20, 2007, 08:28:55 PM
Title: torque sequence
Post by: sebastien on May 20, 2007, 08:28:55 PM
what is the proper torque and sequence for a small block cast iron intake manifold and original exhaust manifolds?
also,is that correct that there is no gasket betwwen the heads and the exhaust manifolds?
Title: Re: torque sequence
Post by: dab67 on May 21, 2007, 05:21:09 AM
Sebastien:
Let's see if this comes out correctly. Sequence for SBC Intake. I have nothing on the exhaust.
Dave
Post by: dab67 on May 21, 2007, 05:27:14 AM
Sorry it will not load, wrong format,
Looking at engine from front
Right Side(Passenger) sequence numbers are  12,11,4,1,5,and 6 for the very back
Left side(Drivers) sequence nmbers are 10,9,3,2,7 and 8 for the very back
30 pounds torque with oil.
Hope this helps
Dave
Post by: 1968RSZ28 on May 21, 2007, 11:50:54 AM
Sebastein -
All this info is in the factory Chassis Service Manual & Chassis Overhaul Manual, which can be purchased at most first generation Camaro part retailers.   :)
Post by: sebastien on May 21, 2007, 02:59:07 PM
ok thanks,I have the chassis manual.iI'll double check.
Post by: JohnZ on May 22, 2007, 09:59:51 AM
Quote from: sebastien on May 20, 2007, 08:28:55 PM
Correct - no Chevy V-8 ever used exhaust manifold gaskets, although the aftermarket gasket manufacturers seem compelled to include them with their gasket kits.
