Camaro Research Group Discussion => General Discussion => Topic started by: DANW on May 20, 2007, 01:35:46 AM
Title: door striker
Post by: DANW on May 20, 2007, 01:35:46 AM
The door striker has a annular metal ring or sleeve on it where the latch contacts it that rotates with some effort.  How easily should this be able to turn?  Is it supposed to rotate on contact with the door latch?  I appears to have rubber between the rubber and the pin and ring.  How should it be lubed?
