Camaro Research Group Discussion => General Discussion => Topic started by: gary on February 18, 2025, 05:40:42 PM
Title: reproduction body or other orginal body
Post by: gary on February 18, 2025, 05:40:42 PM
Hey guys and gals, I'm needing to know what you think I  should do. I have a 1968 Z/28 with lots of options and all orginal numbers with paper work and protecto plate. The body is so bad that I would have to change nearly every part. Do I buy a repo
body or rebuild this one or I also have a 68 body that has NO rust. What do you think?  Thanks for you input. Gary
The good body is about 4 months different in build date.
Title: Re: reproduction body or other orginal body
Post by: mls68z28 on February 18, 2025, 07:01:22 PM
Can you do most of the rust work?
Post by: x66 714 on February 18, 2025, 08:21:42 PM
Some pictures would be helpful. The repop bodys arer't exact. Using the rust free body would meen changing VINs....maybe. Maybe grafting the 2 together might be an option. I would try to retain as much of the original car as possible. But then again, I live in southern Arizona & don't really see these problems...Joe
Post by: gary on February 19, 2025, 07:29:05 AM
yes I can do the rust work. Not much of the body can be used. Thanks for your input Gary
Post by: David K on February 24, 2025, 10:16:42 AM
In my world,  as long as the trim tag, VIN plate, and firewall with the hidden VINs are intact as a unit, it doesn't matter. What is your end goal?
Post by: 169INDY on February 24, 2025, 01:30:22 PM
"options and all original numbers with paper work and protecto plate."
easy for me to say: At all cost Fix what is available, rebody gets you in a stick situation in my opinion
Of Course Pics would be interesting as usual.
Post by: gary on February 24, 2025, 05:48:03 PM
Thanks for your input. I'm leaning towards rebuilding it. Thanks everyone, Gary
