Camaro Research Group Discussion => Originality => Topic started by: gwp4 on May 06, 2024, 11:16:30 PM
Title: Factory Correct Vacuum Advance - 1968 Camaro
Post by: gwp4 on May 06, 2024, 11:16:30 PM
Hi Camaro Experts -
I have a 1968 standard base model cpe Camaro 327/210 HP SB manual 3 spd with no a/c.  I'm being judged in the Legends class and need the factory correct vacuum advance.  The original distributor on the car has the number 1111440 with a date code of 8D8 (April 8, 1968).  The car was manufactured on May 14, 1968 so it's correct.  The Legends judging manual for 1967-1968 Camaros does not have the 1111440 distributor number listed.  I believe the vacuum advance should be MS 201 15 but I'm not sure.  Many thanks in advance for the assistance.  gwp4
Title: Re: Factory Correct Vacuum Advance - 1968 Camaro
Post by: bcmiller on May 07, 2024, 10:04:08 AM
A lot going on for me but I can try to see what I have. I bet I have 3 dozen or more distributors from 1966 to 1971.
Post by: GMAD_Van Nuys on May 07, 2024, 04:49:15 PM
Prior CRG posting about distributors used on the 1968 Camaro:
http://www.camaros.org/forum/index.php?topic=4548.0
I haven't found any documentation on the vacuum advance used on the 1111440 distributor and perhaps the information is available if someone has a vintage Delco catalog.
Post by: His67PC on May 08, 2024, 08:40:53 AM
According to my 73 Delco catalog, 1111440 distributor received D1382 Vacuum Control.
Post by: rare396bronze on May 08, 2024, 10:37:22 AM
My 1968 delco book say's the gm number is 1115355 which should be MS 355 for 1111440 distributor.
Post by: mls68z28 on May 08, 2024, 11:29:09 AM
I have dist. 1111150  7E 8 that has 201 15  vac. Let me know if you want it,Mitchell
Post by: KurtS on May 08, 2024, 02:09:09 PM
Quote from: rare396bronze on May 08, 2024, 10:37:22 AM
Correct. The GM # is 1115355.
Post by: PHAT69AMX on July 13, 2024, 10:15:03 PM
Old notes show 1115355 = Borg Warner V280P , also VC1765, all brands stamped "B20" on vac adv can mtg flange, vacuum advance starts at 5.0"-7.0" Hg
