Camaro Research Group Discussion => Decoding/Numbers => Topic started by: william on May 31, 2023, 09:17:02 PM
Title: Caveat Emptor...tags
Post by: william on May 31, 2023, 09:17:02 PM
https://bringatrailer.com/listing/1969-chevrolet-camaro-z-28-136/
124379L507447
L507447 was final assembled on or about November 7, 1968. Car has an 11B body tag, second week November 1968. Data on the tag does not compare with other L507xxx VINs. The VIN tag is attached with common pop rivets due to dash top replacement.
One or both tags are not original to the car; hidden VINs may not match.
Title: Re: Caveat Emptor...tags
Post by: boomer632 on June 01, 2023, 07:07:29 AM
Good catch. The one pic of the firewall, TT is missing...
Post by: MO on June 01, 2023, 11:15:59 PM
Wow!! The vin tag rivets are only part of the problem.
Post by: Turboragtop on June 15, 2023, 10:39:45 AM
Where is the hidden VIN located?
Post by: MO on June 15, 2023, 11:36:24 PM
One is located on the passenger side inside the cowl vent area. Look down into the cowl area beneath the cowl panel louvers and above the heater box.
Post by: bertfam on June 16, 2023, 08:04:34 AM
Pictures of where to look HERE (http://www.camaros.org/numbers.shtml#PartialVIN).
Post by: Jonesy on June 25, 2023, 05:16:58 PM
Was bid to $55,000, reserve not met. Wow.
