on a early build 3 week of sept 68 where is the small wire off the negative battery cable mounted to is it the fender or the core support
http://www.camaros.org/forum/index.php?topic=20636.msg187733#msg187733 (http://www.camaros.org/forum/index.php?topic=20636.msg187733#msg187733)
I don't know what battery was in it from the factory
Quote from: ALLZS on May 04, 2023, 03:45:28 PM
At this point, unless you have original paper work, you kind of have to guess. A group 22F could be used if you want it like it was from the factory or you have to use a group 24 & call it hd battery. I believe these are both discussed in the assm manual....Joe
Do you have the original core support for the car?
Are you building a concourse restoration?
I FOUND MY ANSWER IT DOES GET MOUNTED TO THE CORE SUPPORT
