Camaro Research Group Discussion => General Discussion => Topic started by: Ron C. on April 28, 2007, 04:09:14 PM
Title: Jerry the intake looks great!
Post by: Ron C. on April 28, 2007, 04:09:14 PM
Jerry, Thanks a lot for the nice job you did on my 67 intake, it really makes the engine look good. Cant wait to get it in the car! ;D
(http://i96.photobucket.com/albums/l188/Budbrewer1/P4280009.jpg)
(http://i96.photobucket.com/albums/l188/Budbrewer1/P4280008.jpg)
Title: Re: Jerry the intake looks great!
Post by: 1968RSZ28 on April 28, 2007, 05:56:50 PM
Ron -
Your engine looks great!  I was just wondering if the engine lifts brackets are original?  I thought only the big blocks got them in '67.   ???
Post by: Ron C. on April 28, 2007, 06:06:16 PM
Yes your correct! im useing them only to install motor then they come off! Supposedly no lift brackets were left on the Z motors in 67.Please correct me if im wrong ;D
Post by: Jonesy on April 28, 2007, 06:23:53 PM
No engine brackets is correct. Engine looks great.
Post by: 1968RSZ28 on April 28, 2007, 06:42:46 PM
Did the '68 302s get engine lift brackets?
Post by: Ron C. on April 28, 2007, 06:46:41 PM
I dont think so,not untill 69 I think
Post by: Jerry@CHP on April 29, 2007, 08:51:02 AM
1968 engines did receive engine lift hooks.
JM
Post by: sebastien on April 29, 2007, 01:38:21 PM
all 68 engines? or only 302?
Post by: Jerry@CHP on April 29, 2007, 08:22:46 PM
All engines.
JM
Post by: AFONEFE on April 29, 2007, 08:38:05 PM
NICE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!  :D
Post by: 1968RSZ28 on April 29, 2007, 11:36:09 PM
Quote from: Jerry@CHP on April 29, 2007, 08:51:02 AM
JM
Ugh!!  Mine are missing.  Jerry, did all the small blocks use the same ones?  Are the ones for 1968 engines the same as any other years?  Do they have any special stampings or (insert here) on them?  Thanks in advance.
Post by: 1968RSZ28 on May 05, 2007, 09:49:41 PM
Quote from: 1968RSZ28 on April 29, 2007, 11:36:09 PM
JM
Anybody?
Post by: Jerry@CHP on May 06, 2007, 08:07:31 AM
All 68 and 69 small blocks use the same engine lift hooks.  One hole in each hook.  What I don't understand is how everyone is mis-led using the 1970s double hole front hook.  Every time I go out on the road, most small block cars that I inspect have that double hole lift hook.  Many are buying the incorrect stuff or getting bad information.
Jerry
Post by: 1968RSZ28 on May 06, 2007, 11:24:30 PM
Thanks Jerry!  I wanted to be sure before I start my hunt.
Post by: Flowjoe on May 23, 2007, 02:17:37 AM
Quote from: Jerry@CHP on May 06, 2007, 08:07:31 AM
Jerry
when you say "double hole" are you referring to the large hole through which the hook passes or the small hole through which the intake manifold bolt passes to secure the bracket to the engine?
Post by: Jerry@CHP on May 23, 2007, 06:51:15 AM
Meant double hole because it has two mounting holes to fasten it to the intake.  I have photos of correct lift hooks in my Camaro fact book.  Look at the engine bay on the Brandenburg car.
Jerry
Post by: dab67 on May 23, 2007, 12:08:13 PM
Jerry:
What about 67's Did they have engine lift hooks or were they the black sheep of the generation?
Dave
