Camaro Research Group Discussion => Originality => Topic started by: luv2sixty9 on November 14, 2022, 11:40:19 AM
Title: Correct Oil fitting L35
Post by: luv2sixty9 on November 14, 2022, 11:40:19 AM
Wanting to ascertain, which is the correct original one if any for a 05E NOR68 Camaro SS 396/325hp with Oil Light / Idiot Warning Light.
I believe it's the top one but not absolutely sure.
Looking for concrete answers no guessing. Thanxs in advance
Title: Re: Correct Oil fitting L35
Post by: 169INDY on November 14, 2022, 11:46:09 AM
My LOS (12E) is equipped with the middle set up.
Post by: luv2sixty9 on November 14, 2022, 12:03:05 PM
12E of 67, so early 68 LOS car? Mine is a NOR 05E of 68
Post by: 169INDY on November 14, 2022, 10:27:20 PM
Quote from: luv2sixty9 on November 14, 2022, 12:03:05 PM
Correct Model Year 1968
Post by: 68 TT on March 08, 2023, 03:18:42 PM
My 01C LOS 396 car has the upper one-piece 45-degree fitting.
It makes sense that they would use as few pieces as possible to eliminate parts, the labor to assemble them and possible oil leak locations.
Post by: big iron on March 13, 2023, 12:28:05 PM
Top picture is correct for 444052 elbow used on 67 68 69 2 bolt BB's. When the AIM RPO L35/U17 instructions where drawn they added the bushing 444026 / 444030 U17 which is not used on 2 bolt blocks but 444030 is used on 4 bolt blocks.
2 bolt BB blocks are drilled for 3/8" NPT and 444052 elbow screws directly into it with no adaptor ( bushing).
4 bolt BB blocks are drilled for 3/4" NPT and 444030 reducer bushing (3/4" to 1/2")  is needed but 444052 elbow is not used.
Bob
