I just saw this 69Z pop up on BAT.
VIN: 124379N622010
The trim tag appears ok to me at first glance, but I was hoping it was in the CRG system. I was really intrigued with the stamps on this one. The motor has obviously been decked so could be a re-stamped pad, but the partial VIN in the rough casting looks a bit different. it appears the partial VIN on the trans the 6 is upside down? Also the rear end stamp looks like BB? or is it a bad BS stamp?
thoughts?
https://bringatrailer.com/listing/1969-chevrolet-z-28/
Information about this 1969 Z28 from a previous sale:
https://www.barrett-jackson.com/Events/Event/Details/1969-CHEVROLET-CAMARO-Z/28-COUPE-21478
If you blow up the engine vin there is another set of numbers there. I dont like either stamps and the suffix is not normal. My Z is the same week
I do see what looks like another 2 and a 3? When I look closer at the partial VIN. Good find Bill
Tag looks good; not the engine stamp.
Rear springs are not original.
Tag needs more sanding, just to be sure.
I hope you are joking about the "more sanding".
Tag is good. Nothing else is though drivetrain wise.
The engine pad stamping has been restamped for sure
The partial VIN in the rough casting has definately been restamped also. You can make out some of the original numbers.
Alternator is a restamp also
Rear axle stamping B? 1206 G2 the second digit looks altered and doubtful this Dec 6th rear came in the car from factory.
Not a $91K car IMO.
