Camaro Research Group Discussion => Originality => Topic started by: vtfb68 on December 01, 2021, 06:21:46 PM
Title: Odd bulkhead cutout, original ?
Post by: vtfb68 on December 01, 2021, 06:21:46 PM
Hi guys,
our Jan. 67 convertible has a a cutout on the bullhead (that is under the cowl top vent, near the hidden VIN)
it extends the outboard passenger side hole to the firewall. its about 2.5" wide and has mounting holes. it sits above the A/C box.
i have never noticed this on any other car. Is there something I'm missing or just some kind of old add-on.
All related thoughts welcome.
Thank's Again,
     VT
Title: Re: Odd bulkhead cutout, original ?
Post by: KevinW on December 01, 2021, 06:54:13 PM
It is your MAX Air/Fresh vent.  There should be a small hole nearby into the interior where a vacuum line goes.  It is normally open to allow fresh air into the fan.  When you select MAX air, it closes off the cowl, opens the pass kick panel vent and forces the fan to pull air from the pass side kick panel.
Not sure if available new, probably a used item.
Post by: KevinW on December 01, 2021, 06:57:44 PM
There is one on Ebay now for $125 https://www.ebay.com/itm/233911817104?hash=item36763b1390:g:4R4AAOSwxFRgOWi6
Post by: CantRepeat on December 02, 2021, 04:50:21 AM
Is this the area you're talking about?
Post by: vtfb68 on December 02, 2021, 02:40:16 PM
Thank you Kevin and Tim, That is exactly what I was talking about, the pictures are great.
(BTW the car is a 11B)  Tim, my seats do not have the horseshoe pattern, do yours ?
  Thank you guys,
   Victor
Post by: CantRepeat on December 06, 2021, 04:37:26 PM
Quote from: vtfb68 on December 02, 2021, 02:40:16 PM
  Thank you guys,
   Victor
My car does have the horse shoe which I believe is the same for all deluxe interiors in 67; mine is a deluxe parchment car.
