Does 08 9 V on the machined surface on the bottom of the passenger side back corner indicate a Flint assembly date on a CE block?
The block is a 3970010 with a casting date of G 28 9
Aug 1969 Assembly Date which does align with the casting date of July 28th 1969 Casting date.
"Starter" mounting pad.
JIM
What does the V stand for? 5th week?
not 100%sure but it looks like CE0 if I am right it was 1970. The rest I just dont know.
My CE block in my 68Z is CE9B 9 for 69, and I read the B was for short block.
V on the oil pan rail surface would be for Flint V8 assembly. There are pictures of similar stampings in the CE thread here: http://www.camaros.org/forum/index.php?topic=12873.0;all
Quote from: Coltdogg556 on August 21, 2020, 10:26:54 PM
Per GM's letter, the 'B' represents the 3rd time thru the sequence numbers for that year's CE blocks... ie. after the first pass, it goes to A..., then B...
