Camaro Research Group Discussion => Maintenance => Topic started by: sabino56 on December 08, 2019, 04:32:21 PM
Title: Retainer for cable in dash - 68 camaro
Post by: sabino56 on December 08, 2019, 04:32:21 PM
Hi,
I had to pull the pedal asm out to fix it. I'm putting back in and can't find where the main cable bundle is retained. Looking at plastic clip, I'm not sure it ever was.  Picture is in thru opening where gages would normally be located.  The end of the brake return spring is sticking up thru the pedal asm bracket and the cable is touching it if not retained somewhere.  There is a hole up close to the dash support at top - white arrow, but the cable doesn't have enough slack to reach it.
I'm wondering if I'm missing something obvious or I need to figure out why cable doesn't have enough slack to get up to that hole.
Thanks in advance for any advice
Title: Re: Retainer for cable in dash - 68 camaro
Post by: althomas55 on December 08, 2019, 09:16:03 PM
worked on mine a couple times under the dash ,can't recall where that cable wrap pushes into, but do recall anything I ever did under the dash was a real PITA !!!!
