Camaro Research Group Discussion => General Discussion => Topic started by: red69 on December 31, 2018, 07:05:05 PM
Title: 302 with crossram dyno numbers
Post by: red69 on December 31, 2018, 07:05:05 PM
Rebuilt my 69 Z engine this past year. Been in the car for 35 years and I decided to go through it. Only variations from stock specs are .040 overbore, 3927140 off road camshaft, stiffer valve springs, 69 GM crossram, and 1 5/8"primary 3" collector equal length headers. Best numbers were 370 lbs. torque @5700 and 417 H.P. @ 6700.
Title: Re: 302 with crossram dyno numbers
Post by: uscrichter on December 31, 2018, 07:14:32 PM
Very impressive HP numbers! What ignition are you running? I'm about to do a similar set up on my Z with a Vintage T.I. set up.
Post by: JohnSlack on December 31, 2018, 08:52:28 PM
Quote from: red69 on December 31, 2018, 07:05:05 PM
Compression ratio?
Post by: red69 on January 01, 2019, 05:48:11 PM
Ignition is stock distributor and coil, plugs are 44 Autolite, 36 total advance. Compression is 11.1, the combustion chambers are a little big, came that way from factory, and I wanted to run a composite head gasket, so I had J&E make pistons to my specs.
