Camaro Research Group Discussion => Originality => Topic started by: Fanthomgreen69 on September 15, 2016, 02:37:57 PM
Title: Intake manifold bolts/Engine lift hook brackets for SB
Post by: Fanthomgreen69 on September 15, 2016, 02:37:57 PM
Ordered an engine lift hook brackets(1256599) from Classic Industries.(Came with Paragon instruction) They offer 2 different ones. The other is HC70. They both show they are for a SB. The one I ordered looks to be the original type that came on the '69 Z/28.  The right rear bracket bolts to the bellhousing. The other one just bolts to the intake. How much longer does this bolt need to be? Also ordered the intake manifold bolt kit. They don't offer a bolt kit with the 2 longer flange bolts. On a previous thread someone mentioned a certain flanged bolt size(3/8 16x1-1/4) from AMK. I called AMK. The lady I spoke with told me that bolt was for a big block. Don't want to order the wrong/incorrect bolts.  I am confused. Which lift bracket is correct for my application and what are the correct longer flanged bolts and the AMK part #.  Thanks for any help.
Charles
Title: Re: Intake manifold bolts/Engine lift hook brackets for SB
Post by: Kelley W King on September 15, 2016, 04:39:14 PM
I took my set off an old 69 327. They do not bolt to the bell housing.
Post by: 68camaroz28 on September 15, 2016, 06:17:17 PM
Quote from: Kelley W King on September 15, 2016, 04:39:14 PM
Agree it does not bolt to bell housing. And agree that the flanged bolt used for lift brackets is what was used on BB manifolds.
Post by: crobjones2 on September 16, 2016, 12:24:42 PM
If I am not mistaken
They attach to the last hole on the intake on the passenger side, with the hole facing the firewall, and the second hole on the intake on the drivers side.
all of my bolts were the same , all have the same head stamp
they are similar to these:
http://www.heartbeatcitycamaro.com/store/product/21541/Camaro-Engine-lift-brackets-SB-1965-1966-1967-1968-1969-UP/
Post by: BillOhio on September 16, 2016, 01:23:06 PM
Bolt and bracket
Post by: Fanthomgreen69 on September 17, 2016, 01:34:07 PM
Bill,
Thx for the photo. I have seen quite a few pics of the driver's side bracket, but yours is the first showing the passenger side. Having a heck of a time trying to find the longer bolts. A lot of places sell the brackets and a bolt kit, but not a kit with the 2 longer bolts or just the longer bolts. Where did you find the flange bolt and how long is it?
Charles
Post by: BillOhio on September 17, 2016, 06:30:14 PM
I found it in that hole lol. Front is same.
Post by: Bryan302 on September 17, 2016, 08:13:43 PM
Is it possible that certain build dates, or early or late factor, determine whether or not 69 Z's got flange bolts on the lift brackets?
I'm seeing some say yes, some say no?
This thread said yes.
http://www.camaros.org/forum/index.php?topic=11704.0
Bryan
Post by: Bryan302 on September 17, 2016, 09:03:39 PM
Well, let me re-word that.  Did ALL 69 Z's get the flange bolts on the lift brackets?  Some vendors and some owners insist that all bolts were the regular hex head.
