Anyone want to take a guess what this was?
Drivers side front cylinder. Pan rail is at bottom
CK?
I thought OK but weird its there
I have seen DZ and 302 on the block sides in the past.
I have a 6,000 mile 70 Z28 engine and CTB can clearly be seen both sides of the block . I too have seen DZ on 302.
Well theres no CK engine suffix for a chevy engine, could be a CR which is a 1958 Corvette 283, or maybe it is an OK.
My vote is with 'OK'
It's good to see these marking were done while the engine was assembled and prior to painting over them and surviving today.
All engines had what would ultimately become the stamp pad suffix scrawled on the side of the block in grease pencil; that was done in the first operation on the engine assembly line, where the block was upside-down and the bores were air-gaged. That marking told everyone on the line what innards and external parts to install in the block (cam, crank, rods, pistons, oil pump and pickup, pan, balancer, lifters, heads, intake, water pump, valve covers, distributor, etc.). The pad didn't get stamped until the engine was turned right-side-up and the heads went on.
Hi John,
I thought the engine prefix stamp was applied before the heads were mounted which explained why some of the stampings were close to the head to deck edge or under the water plug protrusion as with BB's. Or was it different between BB and SB in regards to when the pad was stamped in relation to the head mountings?
This was on head. Same cylinder
Here is the engine out of the blue 69 Z I recently restored.
(https://lh3.googleusercontent.com/-UV2bmQ1x-AQ/USB1myHea_I/AAAAAAAAB3w/UoG0gnf29n4/w800-h549-no/69_LB_Z_10D_302_on_block.jpg)
Quote from: Mike S on March 29, 2014, 10:28:56 AM
Hi John,
Yes, BB were stamped without heads installed, SB with the heads installed
Interesting! I was cleaning up a Flint CE block recently and noticed yellow grease pencil marks on one side (which I have left undisturbed); Would the same process as JohnZ described have applied equally to a CE assembly as a production engine?
Mine looked to be yellow but I do wonder if they were white that aged?
Hi John,
On small-blocks, the machine code stamp was done after the heads went on; on big-blocks, the machine code stamp was done BEFORE the heads went on so the stamp could be done on the outboard end of the pad without having the big threaded plug in the head in the way of the gang-holder. Big-blocks had to be done that way so the car assembly plants could stamp the VIN derivative on the INBOARD end of the pad, where there was no plug in the way of the stamp.
Quote from: ZLP955 on March 29, 2014, 05:07:11 PM
Yes - the only difference was that a "CE" engine was a short-block, so it didn't get heads, an intake, a water pump, distributor, or an oil pan. This made them difficult to handle (had to be done manually with hi-lo's and wooden pallets when they got to the end of the line), so they were usually run on weekends.
Great, thanks again as always John! Now I'll have to try and decipher the crayon markings.
Havent seen a lot of these but the ones I did see were horizontal - if that is "OK" written there then it looks like it is on the vertical plane. (If that maked sense). It does not look like a typical engine suffix location/orientation is what I would say.
-Mark.
It is vertical. O is by the pan. Or what ever it is
New member and first post for me. I was cleaning up the engine I am going to use in my Camaro yesterday and noticed the same yellow colored markings. The engine is not original to the car and is a 69 HK code motor 300 horse L48 from an impala. Has HK very clearly on the passenger side head and upside down on the side of the side of the block. Also appears to have PS on the other side of block. Anyone have any idea if that could denote power steering? Engine has more crayon behind the motor mounts I will try to get uncovered and try to decipher as well. I can try to get any pics if anyone is interested.
1970 6,000 mile LT1
Great photo Mike, and nicely preserved. Must be a nice car, reminds me of the very low mileage one that Charley found a while back.
No car, it was out of a rolled 6,000 mile 70 Z28 that was wrecked around 70-71.
Ah, pity the car was lost, but explains such a low-mileage engine!
Seen this in how to hotrod your small block chevy
