Camaro Research Group Discussion => Originality => Topic started by: DT on September 21, 2013, 08:53:36 AM
Title: "837" alternator deep grove pulley
Post by: DT on September 21, 2013, 08:53:36 AM
Did the deep grove alternator (#1100837) pulley have a notch in it???   I have seen some deep groove alternator pulleys without a notch in it??
Title: Re: "837" alternator deep grove pulley
Post by: JohnZ on September 21, 2013, 10:29:45 AM
Here's an original - where's the "notch" you asked about?  :)
Post by: DT on September 21, 2013, 11:29:09 AM
Thanks John, The notch is under the nut, like a keyway kind of thing.  See the "notch" in the fan??  Does the pulley have this??
Post by: ko-lek-tor on September 21, 2013, 03:43:16 PM
No, never have I seen a deep groove from a 837 with a keyway, only the fan. I have 3 originals to compare.
Post by: ZLP955 on September 21, 2013, 06:33:16 PM
I believe the '67 Z28 and L78 alt pulley had the notch you're describing.
Post by: DT on September 22, 2013, 04:05:38 PM
Thank you guys.
