Camaro Research Group Discussion => Maintenance => Topic started by: DonSTP on August 29, 2006, 09:49:02 PM
Title: Temperature sensor in engine block
Post by: DonSTP on August 29, 2006, 09:49:02 PM
Curious if anyone's removed the temp sensor in their engine block if they had to drain the coolant from the block first?
Thanks -
Title: Re: Temperature sensor in engine block
Post by: JohnZ on August 30, 2006, 11:12:48 AM
There aren't any temp sensors in the engine block - only in the cylinder head or intake manifold. You need to drain enough coolant to get the level below that of the sensor before removing the sensor or you'll have a real mess to clean up.
