Author Topic: Freeing frozen piston in master cylinder  (Read 10414 times)
stovebolt
  • 1968 L6 Sport Coupe
« on: September 07, 2012, 05:03:40 PM »
Any suggestions on how to free a piston in my master cylinder. It is the piston at the bottom of the bore. I've soaked it with WD40, blasted it with compressed air, tried hooking it with a piece of wire, all to no avail. Any suggestions would be appreciated. Thanks, Joe.
Re: Freeing frozen piston in master cylinder
« Reply #1 on: September 07, 2012, 05:10:47 PM »
 Did you remove the retention screw from the floor on the inside?
stovebolt
« Reply #2 on: September 07, 2012, 05:14:06 PM »
Yes, I did remove the stop screw.
« Reply #3 on: September 07, 2012, 07:09:06 PM »
Can you MAKE a grease fitting to fit into a hose fitting? Block the others and pump it full of grease.
stovebolt
« Reply #4 on: September 08, 2012, 08:11:21 PM »
Thanks, I will try that.
stovebolt
« Reply #5 on: September 26, 2012, 05:51:07 PM »
I made an adaptor by turning a metal rod to a squeeze fit in a brake line fitting then drilled and tapped it to accept a standard zirk grease fitting. After blocking off the three holes at the bottom of the reservoir with a piece of hard rubber and a C-clamp, I pumped in grease with my standard pistol-grip grease gun and out it came.
Thanks for the suggestion.
« Reply #6 on: September 26, 2012, 10:47:26 PM »
Cool beans, glad it worked for you. I'm thinking a standard grease gun produces something like 1200 PSI, multiply that times the area of the piston and that's how much pressure you have. The grease is cheap to fill the cavity and can be reused.
« Reply #7 on: September 27, 2012, 03:53:41 AM »
Has anyone bought a Master Cylinder Rebuild kit recently?    Any suggestions on source for one?
tmodel66
« Reply #8 on: September 27, 2012, 01:29:02 PM »
I know I keep beating the NAPA "Drum" but they either had all this stuff or could get it over night. I used Wagner and Bendix brake stuff. The good thing about NAPA (well my NAPA guy) he tells me if it's import or not and can get the good stuff  (made in USA)  95% of the time.
