Author Topic: Opinion needed-engine/tranny first or front end?  (Read 7702 times)
Springer Tom
« on: September 03, 2012, 01:33:37 AM »
Had to remove the right front fender and skirt, bumper, grille,valance, etc to install A/C box....seems to me it would be easy to remove radiator support,put engine and tranny together on the floor and slide them right in, then put the sheetmetal back on.....chime right in please
tmodel66
Re: Opinion needed-engine/tranny first or front end?
« Reply #1 on: September 03, 2012, 02:00:18 AM »
That's what I would do if I already had it that close to being apart.   Go for it !!
rich69rs
  • LF7/M35/Z22/Z87
« Reply #2 on: September 04, 2012, 03:10:01 PM »
If you are that far - absolutely
Richard Thomas
1969 RS
Springer Tom
« Reply #3 on: September 04, 2012, 03:44:43 PM »
Thanks guys
hotrod68
  • almost finished
« Reply #4 on: September 07, 2012, 02:31:38 AM »
If I still had the left fender and header panel/valance panel intact, I'd put the front end back together while that much is still aligned. If you take the entire front clip off--including the radiator support--unless you're a good body man you're going to have a hell of a headache getting everything back the way it was. As for me, I'd much rather slide an engine/transmission in through the sheetmetal than fight shims and dents and unaligned fenders and the like. But then, I hate bodywork. Good luck!
