Author Topic: GM 3905525 Metering Valve Disassembly and Rebuild  (Read 11371 times)
sah62
    • Muscle Car Research LLC
« on: September 01, 2012, 07:36:58 PM »
I've just completed disassembly and rebuild articles for the GM 3905525 metering valve made by Bendix for 1967 - 1969 GM vehicles. I've also got a new seal kit available that I'll post in the classifieds. Here's the disassembly article:
https://www.musclecarresearch.com/gm-3905525-autopsy
The rebuild article:
https://www.musclecarresearch.com/gm-3905525-rebuild
I don't yet have a reproduction of the Bendix rubber dust cap. I'm exploring my options to see if it can be done economically.
« Last Edit: September 01, 2012, 08:04:16 PM by sah62 »
Scott Hollenbeck
Administrator, Mustang 428 Cobra Jet Registry
Owner, Muscle Car Research LLC
1970 Ford Mustang R-Code Mach 1
2006 Dodge Charger SRT8
1995 Chevrolet Impala SS
Re: GM 3905525 Metering Valve Disassembly and Rebuild
« Reply #1 on: September 01, 2012, 10:06:19 PM »
 Perfect timing...
I am looking at mine and could not figure out how to extract the internals until I had seen your article.
As for a classified section, CRG has none specifically but if you post the info here I believe it will spread quickly as many here have the same setup and likely ageing conditions.
I'm certainly interested in what you have.
Thanks!
sah62
« Reply #2 on: September 01, 2012, 10:35:25 PM »
OK, then here's a link to the kit:
https://www.musclecarresearch.com/gm-metering-seal-kit-1
$9 plus shipping.
Scott Hollenbeck
« Reply #3 on: September 02, 2012, 02:46:38 AM »
 I placed my order plus the differential valve kit.
I was surprised how good the unit looks from the outside and the amount of brown crud on the inside.
Based on that I'm going to rebuild the brake pressure differential valve because I'm sure that has crud too.
The rest of my brake components are either new or rebuilt.
Thank you for the very well prepared instructions too!
sah62
« Reply #4 on: September 02, 2012, 12:05:32 PM »
Glad to help, Mike. I'll have your items in the mail on Tuesday when the USPS gets back to work.
Scott Hollenbeck
« Reply #5 on: September 02, 2012, 06:45:59 PM »
Excellent work - thanks!  :)
« Reply #6 on: November 25, 2012, 06:23:17 PM »
Should be metering valve and brake switch unit be painted or 'natural' for factory original finish?   The bracket for the brake switch from my car appeared to have been 'dipped', and the metering valve bracket appeared to have been natural finish...  I went wild back in the 70's with my krylon and sprayed everything, so now between my overpaint and my 'old/bad' memory, I have no idea..  :)    Any help appreciated as I cllean and reinstall these items.
Gary
« Reply #7 on: November 25, 2012, 07:38:42 PM »
 The metering valve (or hold off valve) on my 67 had a parkerized finish like a firearm for the front cap. The body I am not sure of but all I can see on my survivor was surface oxidation so it was either unplated or any black paint applied back then wore off. The reproduction plating I have seen are wrong, at least for 67 from what I have seen so far.
More info can be found at: http://www.camaros.org/forum/index.php?topic=9970.0
As for the bracket I suspect it was likely dipped too and that would be 60% gloss black.
sah62
« Reply #8 on: November 25, 2012, 08:34:11 PM »
Has anyone ever seen one of these valves that didn't use a u-cup seal where the end of the spool valve rod comes through the valve body? I recently heard from someone who found such a valve on a '69 Malibu. The body wasn't machined for a seal - picture attached.
Scott Hollenbeck
sah62
« Reply #9 on: March 12, 2016, 06:59:30 PM »
I now have a reproduction of the rubber dust cap that came with this valve:
https://www.musclecarresearch.com/cap-1
$10 plus shipping.
Scott Hollenbeck
m22mike
« Reply #10 on: March 20, 2016, 12:16:18 PM »
No, not to date, have done 6 or 8 so far. If that is the case, as in your picture, I would suspect it may be machined to accommodate a "O" ring vs a cup seal.
X66 L78 M22 4.10 Deluxe Threads, PNT 10/10, Red Hockey stripe
Spooky
« Reply #11 on: March 20, 2016, 01:25:08 PM »
Great info! I will be doing mine shortly. Thanks!
Scott
