Author Topic: Early 68' RS Grill Attaching Screws  (Read 16836 times)
Lane 68
« on: August 26, 2012, 05:28:19 PM »
My RS/SS is a 10B build.  In the AIM, Pg 424, Z22 / A4, it shows:
6 = Screw #9419303
8 = Nut #9422836
Does anyone have a picture or know what size srew and nut this was?
Early cars used screws and nuts across the bottom of the GRILLE-LOWER (7) to attach to the LOWER VALANCE PANEL
as pictured in the AIM. I believe the nut had a star washer attached too. I appreciate your help!
Lane
x77-69z28
Re: Early 68' RS Grill Attaching Screws
« Reply #1 on: August 26, 2012, 09:25:15 PM »
if it is the same as a 67, the bolts were attached to the grille mldgs. that bolted to the header panel. the grille was riveted to the upper and lower grille mldgs. the lower grille mldg was riveted to the lower valance.
Lane 68
« Reply #2 on: August 26, 2012, 09:46:21 PM »
Thanks for your response!! ;D
The AIM for 68 (page 424...Z22 / A4...parts 6 and 8)  showing SCREWS and NUTS attaching lower grill to lower valance.
I want to verify this with someone who has an early 68 RS.
My car is a 10B build.
Thanks again
Lane
Lane 68
« Reply #3 on: August 28, 2012, 03:39:25 AM »
Sorry...that was ment to read....
parts 6 and 8 in the previous reply.
Thanks again.
Lane
1968 Z28
« Reply #4 on: August 28, 2012, 02:18:13 PM »
Not 100% verification...but a clue as to what they might look like...
     6 - http://www.amkproducts.com/Catalog_PDF/74-91.pdf  Page 78, right column, fourth one down
     8 - http://www.amkproducts.com/Catalog_PDF/56-73.pdf  Page 66, right column, third one down
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
Lane 68
« Reply #5 on: August 28, 2012, 11:22:43 PM »
Hello Jerry,
Thank you for your response !!
You are right, that type of screw and nut were used on 05 (May) 68' build RS Camaro's and later. (approximately).
I am in search of an early build RS using what appears in the 68' AIM... screw and nut assembly......used from approxinately Sept 67-March 68 (09-03 dates), based on research from the CRG Forum.
Lane
1968 Z28
« Reply #6 on: August 29, 2012, 03:21:21 AM »
Just going by the part numbers you listed....the hardware that is shown in the AMK catalog corresponds with the part numbers you stated in the first post. If the hardware that you are looking for is different than what is described in the AMK catalog, then the hardware you are looking for will have a different part number.  Anytime there was a change of a piece of equipment on the production line, the parts numbers would have changed also.
BTW.....What appears in the drawings in the AIM is not a 100% representation of the parts.  Just because it shows a picture of what looks like a standard nut does not mean the part was in fact a standard nut.  The drawing is only a representation, it could just as well be any form of a nut.  Same way with the screws.
Now if the plant ran out of the appropriate hardware, they could have gone to their local supplier and bought anything they could find.  So....you could possibly have any kind of hardware that would bolt up.
« Last Edit: August 29, 2012, 04:08:48 AM by 1968 Z28 »
Jerry G.
Steve68
« Reply #7 on: August 29, 2012, 12:19:26 PM »
If you have an early original 68 RS front end it would be nice to hear from you on this subject.  A picture would be appreciated too.  Thanks,
Lane 68
« Reply #8 on: September 03, 2012, 05:44:50 PM »
Anyone out there have an EARLY September-November build, 68' RS, they can share some pics.... the attaching screw set up for lower grill attachment to lower valance panel???? ???
Have looked at AIM...and CRG forum...now need some pics to verify.
Need some help.
Thanks!!
1968 Z28
« Reply #9 on: September 04, 2012, 12:42:15 AM »
Lane....I have been doing some further research about the part numbers from the AIM you quoted in your first post (BTW, my AIM states that the page was released on 06-16-1967 and there are no revisions and it shows the same info that you state).
  According to my 1967-1969 Camaro Master Parts Catalog (GM 691A, issue July 1969) those part numbers (8 - #9122836 Nut and 6 - #9419303 Screw) correspond to the part numbers and descriptions in the AMK catalog that I referenced in an earlier post.  I am including some images of the CMPC  pages showing the part numbers.  So if the hardware you are searching for is not the same as described here, I would think that we should then be looking for different part numbers.
     8 - #9419303 Screw.......this is a view of the heading of the screw section describing the coding on the screws
     This view is a shot of the actual part number listing showing the coding of the screw.....refer to the first image to decipher the coding.
     6 - #9422836 Nut.....this is a view of the J/U Nut and the nut listing.
Jerry G.
1968 Z28
Jerry G.
Steve68
« Reply #11 on: September 04, 2012, 01:39:33 PM »
Jerry
When I try your links all I get is an error message.  This link http://www.camaros.org/forum/index.php?topic=1087.msg7557#msg7557 discusses the possible change in parts (such as a shortage) without a part number.
1968 Z28
« Reply #12 on: September 04, 2012, 02:43:50 PM »
Steve...That was what I stated earlier, If they ran out of their supply of the right parts then you could possibly have had anything installed on your car.  I was just trying to show him what the official part numbers were and what they looked like by using the CMPC.  The AIM pictures aren't exactly drawn to perfection.
This is what Lane asked in the first post and I was trying to show him what he requested.
6 = Screw #9419303
8 = Nut #9422836
Those links were working last night.....I'll have to see what happened and post later.
Those were PDF files...maybe you don't have a PDF viewer.  Will have to convert them to JPG's.
« Last Edit: September 04, 2012, 03:01:54 PM by 1968 Z28 »
Jerry G.
Marty
« Reply #13 on: September 04, 2012, 10:49:14 PM »
I have 2 original 9419303 screws. I'll try to take photos but I'm recovering from surgery so it might be a couple days. They're short hex head screw with an indented head. Probably 1/4" socket for the head but I'll check it out.
I'll look for the 9422836 nuts some more. I couldn't find any in my storage boxes.
Martin
Martin Foltz
CRG Member
68 Van Nuys Camaro
Lane 68
« Reply #14 on: September 04, 2012, 11:37:00 PM »
Jerry G. and Martin....
Thank you for taking your time to help.  I would like to see all of the pics and info!!
Jerry, I could not open pics either. (I do have a reader ;D)
I do not disagree with the thought that the "screw and nut" could be a different configuration than what is showing in the AIM but I would like to see a picture or two of a 9, 10 or 11 month 67',  RS build,  lower grill assembly.
Martin, please send me those pics when you are feeling better.
Lane
