Author Topic: Color for horn relay & e-brake brackets  (Read 5216 times)
Springer Tom
« on: August 17, 2012, 09:06:23 PM »
Need the colors for horn relay and the 2 rear emergency brake cable brackets......thanks
Re: Color for horn relay & e-brake brackets
« Reply #1 on: August 17, 2012, 09:32:46 PM »
which rear emergency cable brackets are you referrign to?   the ones that attached to the leaf spring bottom plate? and keep the EB lines away from the wheel? or ??
Springer Tom
« Reply #2 on: August 17, 2012, 09:45:00 PM »
Yes the ones attached to the leaf spring mounting plates
« Reply #3 on: August 17, 2012, 10:38:58 PM »
60% gloss black
