Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Originality
Color for horn relay & e-brake brackets
« previous
next »
Print
Pages: [
1
Author
Topic: Color for horn relay & e-brake brackets (Read 4463 times)
Springer Tom
Member
on:
August 17, 2012, 09:06:23 PM »
Need the colors for horn relay and the 2 rear emergency brake cable brackets......thanks
Tweet
Logged
Hero Member
owner since 4-Apr-1976
Re: Color for horn relay & e-brake brackets
Reply #1 on:
August 17, 2012, 09:32:46 PM »
which rear emergency cable brackets are you referrign to? the ones that attached to the leaf spring bottom plate? and keep the EB lines away from the wheel? or ??
Logged
72 El Camino, '55-'56-'57 Nomads, '55-'57 B/A Sedan
Springer Tom
Member
Reply #2 on:
August 17, 2012, 09:45:00 PM »
Yes the ones attached to the leaf spring mounting plates
Logged
Hero Member
Reply #3 on:
August 17, 2012, 10:38:58 PM »
60% gloss black
Logged
R 68Z build-
http://www.camaros.net/forums/showthread.php?t=182584
Print
Pages: [
1
« previous
next »
Originality
